Help With I4 Rs2k Engine
Old Sep 2, 2008 | 10:10 AM
vaughant's Avatar
vaughant
Default Help With I4 Rs2k Engine
Hi all, only a quickie. I have in my possession an I4 rs2000 motor and also a complete loom engine running gear etc from an escort gti. I`ve considered putting the zetec into my van, but was wondering whether i could use the zetec running gear on the rs motor as i excpect that the timing chain motor would be a bit stronger? Is it worth the bother or should i just out the rs2k motor and continue with the zetec?Many thanks,vaughan.
Old Sep 5, 2008 | 05:34 PM
fonfe's Avatar
fonfe
you have confused me a bit but what i thik your asking is will the rs2000 engine fit onto a zetec box? the answer is yes but only if you use the zetec flywheel and clutch though, dont worry about the crank sensor trigger marks cz the i4 has an internal pickup for that in the sump. i personally went from a 130 1.8 spec zetec to the i4 and much prefer the i4 but its manily cz it sounds so good!
Kyle Langford
27
Aug 5, 2019 07:54 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
