clock cluster Multiplug??
Old Aug 30, 2008 | 05:21 PM
jacko996's Avatar
jacko996
Default clock cluster Multiplug??
Hi
Has any one got a wiring diagram for the multi plug in the back of the dash clocks.
Need to know what each wire does??
Thanks in advance
Dave
Old Aug 31, 2008 | 02:58 PM
jacko996's Avatar
jacko996
Anyone??
Getting desperate
Old Aug 31, 2008 | 02:59 PM
Kelv's Avatar
Kelv
Almost there!
Dave, is this for wiring in a stack, or something similar?
id say speak to Rainbird, as his electrical guru (Ben) knows most of whats what for wiring them in - HTH's
Old Aug 31, 2008 | 06:27 PM
jacko996's Avatar
jacko996
Cheers Kelv
Someone has posted the answer for me now ta.
Another question though.
Does the rev Tacho wire come from the ecu or direct from the coil??
Old Aug 31, 2008 | 08:45 PM
Kelv's Avatar
Kelv
Almost there!
Originally Posted by jacko996
Cheers Kelv
was it for wiring in a new dash unit?
if so, could you forward the details to me aswell please, got towire my stack in soon
as for the rev counter - i cant answer as i have no idea
Old Aug 31, 2008 | 09:23 PM
jacko996's Avatar
jacko996
Here you go dude.
Kelv, can I come round and pick up the seat pads soon if you have finished with them??
pin 1 = BN/GN = Oil pressure switch. (Low oil press light)
pin 2 = BU = Batt (charge) light
pin 3 = BN/WH = Coolant temp gauge
pin 4 = BN/BK = Fuel level
pin 5 = BN = Earth
pin 6 = BK/YE = Main pos +
pin 7 = BN/RD = ABS light.
pin 8 = BN/YE = Hand brake light/Brake fluid level.
pin 9 = BN/WH = Airbag
pin 10 = GN = Rev counter
pin 11 = BN = Earth
pin 12 = BU/WH = Main Beam +
pin 13 = GY/YE = Instrument illum +
pin 14 = BK/GN = indicators
pin 15 = BK/WH = indicators
Old Aug 31, 2008 | 10:27 PM
Kelv's Avatar
Kelv
Almost there!
ill run them down to you tomorrow aft/eve when i get back from Hospital.
Just PM'd you
Mark_
14
Jan 16, 2016 05:27 PM
Sep 28, 2015 10:05 AM
Mr S1
20
Sep 27, 2015 04:06 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
