1st engine start up in ages
Old Aug 29, 2008 | 06:04 PM
rand's Avatar
rand
Default 1st engine start up in ages
Basically my Sapphire Cosworth has been sat in the garage for 15 months and it hasn't been started once in that time!
I'm after advise on what I should do before I start it for the 1st time.
I'll be changing the oil, filter & plugs. I've got new belts except cam belt(would it be worth while regardless?) and changing the water/antifreeze.
Is there anything else I should change/replace as a matter of course?
Thanks in advance
Rand
Old Aug 29, 2008 | 06:08 PM
I would get it running first, then change what you mention, plus fuel filter.
Before you put the new plugs in(old ones out) wind it over on the starter to get oil pressure up, when mine was sat it wouldn't build up, but starting up is okay as it will soon build after a second ot two and engine is not under load.
Just warm up on a fast idle as likely to be a bit grumpy to start with, especially with old fuel.
Old Aug 29, 2008 | 07:06 PM
rand's Avatar
rand
Thanks tabetha, I'll try that
Old Aug 29, 2008 | 11:33 PM
Paul_RS's Avatar
Paul_RS
I'd change the cam belt too - better safe than sorry!
Old Sep 6, 2008 | 01:55 PM
tosh's Avatar
tosh
If like mine it might sound a bit tappety at first but will soon go after a good run, I was told that this is normal.
I know you have probably done it by now but this answer might stop someone else worrying.
Old Sep 6, 2008 | 02:09 PM
mechanic28's Avatar
mechanic28
it will rattle its bollocks off for a while mate!sometimes it can take a good few miles to get the lifters to shut up!as tabetha says remove spark plugs disconnect phase sensor and king lead to eliminate any chance of spark!then spin her over to get good oil pressure and give everything a nice coating!i tend to undo the turbo oil feed pipe from the turbo put it in a cup or something and crank it over until i see fresh oil coming out!then refit pipe crank over again to get turbo all nice and oiled!reconnect everything and fire up!
Old Sep 6, 2008 | 02:19 PM
tosh's Avatar
tosh
Also disconnect the fuel pump as the pump will still be trying to push fuel in while you are cranking it over,
Correct me someone if I'm wrong.
Old Sep 6, 2008 | 02:29 PM
mechanic28's Avatar
mechanic28
you dont have to disconnect the pump!you can if u want but as u got the plugs out and the phase sensor disconected etc i would not worry about it!
Old Sep 6, 2008 | 02:52 PM
Mad Matt's Avatar
Mad Matt
Rally nut
What should I say then, engine hasn't started for nearly 3 years now
steerfromdarear
28
Jan 29, 2016 06:14 PM
ekjim
Aug 17, 2015 08:57 PM
Bailes1992
Aug 16, 2015 07:14 PM
Zoggon
Aug 10, 2015 10:39 AM
