how to fit a mk6 escort sunroof in ur RST
Old Aug 28, 2008 | 05:14 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
Default how to fit a mk6 escort sunroof in ur RST
once you get your old panel out you can compare the bolt holes and as needed use a small file to take out2-3 mm toward the glass the size of the holes and lugs does vary by a tiny amount as i have compared quite a few panels and on some i found that the front locating lug needs to have about 2mm filed off the bottom edge but once you sit your panel in the runners all will become clear,as for shaping the front edge to suit the contours of the roof on the first one i layed a piece of wood on the garage floor layed the panel over it at its centre point and applied pressure to the outer edges dont try to shape it all at once you dont want to over do it i had the panel in and out a few times checking bending checking the second one i done i got the panel against my knee and pulled it backwards using the same checking method .
couple of pics fitted
hope this helps,keep it to yaself tho,keep the prices down
Old Aug 28, 2008 | 05:30 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
and if anyone is interested i have a mk6 escort sunroof that will be going to the tip this weekend, unless some wants it FOC - just need to collect it from swindon!
Old Aug 28, 2008 | 05:40 PM
Spax's Avatar
Spax
Excellent info!
Old Aug 28, 2008 | 07:40 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
what speedlines you got in those boxes?
for sale?
Old Sep 5, 2008 | 07:43 PM
orion_crazy_carl
orion=mini saff
bump
Old Sep 5, 2008 | 08:18 PM
bloopeta's Avatar
bloopeta
Probably a daft question, but why would you want to??
Old Sep 5, 2008 | 08:22 PM
mk3stevie's Avatar
mk3stevie
cause they al rot out and its hard to find a good original one now
Old Sep 5, 2008 | 08:35 PM
bloopeta's Avatar
bloopeta
Ah rite, cheers mate, like I said, prob a stupid question
That will be why I got an eye full of rust the other week when I had sunroof wound back and I hit 80 MPH lol
Old Sep 5, 2008 | 08:45 PM
mk3stevie's Avatar
mk3stevie
Yep! Had one fly out completely once in a mk3 when going down the M27.....didnt look back
Old Sep 6, 2008 | 03:11 AM
bloopeta's Avatar
bloopeta
If its such a common job that needs doing, could someone with the know how not do a full step by step tutorial with pictures for stupid people like me? lol
Old Sep 6, 2008 | 04:12 AM
Turbo Pez's Avatar
Turbo Pez
You just use a early mk5 sunroof, its the same as a mk4, including the part no... runners are different tho
Old Sep 6, 2008 | 05:44 PM
mk3stevie's Avatar
mk3stevie
Didnt know that, well done mate.
Old Jan 5, 2015 | 07:36 PM
peter devereaux's Avatar
peter devereaux
Default s2 sunroof
Hi i have been looking at these instructions and maybe I am stupid but it makes no sense to me. I have a s2 with a rotten sunroof and i have bought a mk6 escort sunroof but the instructions make no sense the sunroof pan is spot welded in so no bolt holes to file out and the screw pattern of the rails is completely different to a s2 any advise would be much appreciated.
Old Jan 5, 2015 | 08:58 PM
tlr_rst's Avatar
tlr_rst
its JUST the glass you need, that fits to the mk4 escort running gear.
remove all you running gear, take off the glass, get you new mk6 glass, files the holes upwards towards the glass, fit to the mk4 running gear job done, i did it in a few hours, once you taking the glass out, then removed the running gear it will make sense, if not I'm in lincoln and can show you
Old Jan 6, 2015 | 07:24 AM
dazrsturbo's Avatar
dazrsturbo
if you are just swapping the glass over theres no need to even take the running gear out of your mk4. simply do as above and just remove the mk4 glass and replace with the mk6 glass. you need nothing else from the mk6 sunroof apart from the glass. as for shaping the mk6 glass to your roof it may need a slight tweak to look perfect. hope this helps
Old Jan 6, 2015 | 11:13 AM
peter devereaux
All fitted thanks for all the help much appreciated
Old Jan 6, 2015 | 04:34 PM
tlr_rst's Avatar
tlr_rst
i took the the running gear to look behind and down the roof to find it rotten, that was the next job, if your glass is rotten so will the back of the roof be
Old Jan 6, 2015 | 09:52 PM
stu20004x4's Avatar
stu20004x4
mk6 escort fantasist
Ive got a few mk6 sunroofs in excellent condition
Old Jan 7, 2015 | 05:54 AM
STeve's Avatar
Super Moderator
quite common for people to swap over the whole frame inc glass from a mk6 onto a S2 with very little modification as all S2 ones rot, I sell plenty of sunroof frames to S2 owners all the time and they all say its a easy to do upgrade
Old Jan 7, 2015 | 07:25 AM
dazrsturbo's Avatar
dazrsturbo
so the whole unit as one will fit straight in? interested to know what mods are needed to do this.
Old Jan 7, 2015 | 09:19 AM
STeve's Avatar
Super Moderator
if you do a search here on passionford you will see this topic has been covered many times, with little more than a few holes widening/relocating etc ,sold 7 last year and one this week and all were bought by S2 owners fitting the whole frame inc glass and none had any bother
Old Feb 3, 2015 | 11:04 PM
Rob_DOHC's Avatar
Rob_DOHC
Great post, thanks very much!
Old Jun 20, 2017 | 10:42 PM
Jlroberts's Avatar
Jlroberts
Sorry for dragging up an old thread, I need a sunroof for my mk5 J reg, I dont think its the sliding one I think it just tilts up, Can I use the glass from a mk6 then?
Old Jun 21, 2017 | 06:04 AM
Rsmat's Avatar
Rsmat
Might have to get a mk6 sunroof in stock for later years .
Old Oct 26, 2017 | 10:20 PM
Jamie Findlay's Avatar
Jamie Findlay
Default S2 sunroof
I know this is an old thread but I'm struggling to find one. I've got a S2 and I need a new sunroof, does anyone have one or even a mk6 sunroof for sale? Cheers
Old Jan 20, 2018 | 04:46 AM
marky_g's Avatar
marky_g
Fleet Manager
I need to do this mines fucked
Old Mar 7, 2022 | 09:43 PM
frodmyster's Avatar
frodmyster
Sorry to revive this post but does anyone know if a mk1 or mk2 mondeo sunroof glass will fit mk3 escort? Apologies if this is a daft question
Old Dec 14, 2023 | 09:45 AM
rsturbolee's Avatar
rsturbolee
It’s the bending I’m confused by its glass?
I’ve just dropped in a mk6 glass
and yes it sits a few mm back and front lip is too high so plan to file it out soon so looks a neater fit
also my rubber looks small in the hole if ask my opinion not sure if rubbers are different, I still have my old glass and rubber
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
A.t.p
Aug 15, 2015 11:37 AM
RsS2daz
Aug 14, 2015 05:26 AM
dlwarrior
Aug 5, 2015 10:19 AM
