fan staying on?
Old Aug 25, 2008 | 07:01 PM
benporter's Avatar
benporter
Default fan staying on?
hi
after a short run today, one (just one of them!) is staying on until i unplug them ie ive given it over an hour to stop.
any ideas what this might be?
thanx
Old Aug 25, 2008 | 07:17 PM
Plug them back in then unplug the fan switch to see it if stops then, if it does it is the switch at fault, if not then fault elsewhere, most likely a stuck relay.
Old Aug 25, 2008 | 07:19 PM
benporter's Avatar
benporter
but why only one of them?
Old Aug 25, 2008 | 11:27 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
As Tabetha said could be a stuck relay or possibly a faulty fan switch.
When the faults happening again, unplug the fan switch. If the fans cut out it will be a switch fault. If they stay on, its likely to be a relay issue.
As for only one working, when the fans are in check to see if you have voltage to the fan that isnt working and also check for a good earth.
If both elements present then it may be a fault with the fan itself. if not you've got a wiring/power/earth supply fault.
Personally I would just pop a new fan switch in and rewire the fan circuit using 1 relay and 1 fuse for each fan. A lot more reliable!!!
Old Aug 26, 2008 | 09:11 AM
JoeRS22's Avatar
JoeRS22
gary u are so knowlegdable....... the AA are privelaged to recruit you!!!
Old Aug 26, 2008 | 10:16 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
You taking the piss?!
Old Aug 26, 2008 | 10:22 AM
rog's Avatar
rog
Do you have an alloy radiator????
Old Aug 26, 2008 | 04:21 PM
benporter's Avatar
benporter
no, just all std ford stuff
Old Aug 27, 2008 | 06:57 AM
rog's Avatar
rog
Ok well it won't be that then, usually you have to change the thermostat (stu @ msd sells them) as the fans cut in all the time, but that's obviously not your issue, hope it's just a relay and you get it sorted out.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
SMILER258
Sep 28, 2015 09:04 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
Flatlinedan
Sep 18, 2015 12:41 PM
