Anyone Got Megasquirt Base map for Esc S1 turbo
i intsalled all my megasqiurt ecu i got from extra efi wired up my wide band no problem, put in my base numbers etc. and way hey its running, problem is as soon as i move the throttle it dies.
running MS1 v3 innovate lc1 cossie 4x4 dark blue injectors(311cc i think) cossie tps wts and ats. fiesta idle valve on efi maifold. slight over bored 1600 cvh low comp pistons piper t2 cam a ported/flowed big valve head stg 2 t3 (20psi) and grs twin pass.
just after a base map to go off if its not too musch trouble, could do with a shove in the right direction.
thanks.
thanks.
thanks for the reply jesse can i burn that msq in to my ecu or input it manually through mega tune?
oh forgot to mention ignition is edis 4. thanks
i'd never ever recommend just burning someone elses settings. You can have a look at it with megatune, or directly with a browser and see what setting I've used etc. You can also copy individual maps easily.
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
