How much will it cost me to....
How much is a half decent 2 litre pinto in these rough specs:
A) cam, tuned a bit, carbs...
B) Standard?
Assuming both engines have a few miles on em, and are in good working order ready to go in a car? £500 tops?
Imagine I had 2wd saff everything in a shell but no engine. Could i just drop a pinto in? Would it mount to a T5 box? (flywheel and clutch depending i guess?)
I'm cunjouring up a supid idea, but chassis work means a YB is out of the question at least for now, so if i dropped it a half decent pinto, I could just swap up to a YB when I get one without having to do too much work?
B) Standard?
heres a link...
https://passionford.com/forum/showth...ghlight=biglee
Lee tis a bit different mate... steve is looking to do somethig and is trying to figure out how much it will cost him to do it.
you had loads of stuff, and was wondering what it was worth!
completely different!
Some sierra's come with a pinto I thought? so it should go in no problem. Not sure if it would bolt straight up to a T5, But I can't see why it won't?
same as YB, will go straight in with right mounts, and bolt to a T5 no probs....
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
