Just fitted new steering wheel....air bag light is now on..
Old Aug 23, 2008 | 11:50 AM
TIFF's Avatar
TIFF
Chasing Radders
Default Just fitted new steering wheel....air bag light is now on..
Just fitted a new wheel to the Audi....but the airbag light is now on.
If i plug it onto a Vag-com will i be able to reset it??
Old Aug 23, 2008 | 11:51 AM
rs1072's Avatar
rs1072
dne that on the mrs scooby months ago still on
gonna sell it soon
Old Aug 23, 2008 | 12:07 PM
rst deany's Avatar
rst deany
Not unless u have the full verision !
Old Aug 23, 2008 | 12:08 PM
TIFF's Avatar
TIFF
Chasing Radders
So it can be reset with the Vagcom then.....
I was going to get one off e-bay
Old Aug 23, 2008 | 12:12 PM
rst deany's Avatar
rst deany
yes mate but not the cheap versions of ebay they are only limited acsess u need the ross tech version.
http://www.ross-tech.com/vag-com/index.html .
Old Aug 23, 2008 | 12:15 PM
TIFF's Avatar
TIFF
Chasing Radders
or i could take it to the local vag garage
Old Aug 23, 2008 | 12:25 PM
rst deany's Avatar
rst deany
or take the bulb out lol
that will be easyst......
TIFF's Avatar
TIFF
Chasing Radders
Think there is a garage in Leamington that can do it.....
Sorted
Old Aug 23, 2008 | 01:02 PM
taycoss's Avatar
taycoss
Someone with a sykes code reader should be able to sort you out as thats what we use,mayby a local garage has one?.Was the clock spring unit put back on in same position and not spun?
Sometimes disconecting battery for 10 mins will let airbag system discharge and re-set itself.
Old Aug 23, 2008 | 01:08 PM
TIFF's Avatar
TIFF
Chasing Radders
whats a clock spring unit?????
Old Aug 23, 2008 | 01:12 PM
taycoss's Avatar
taycoss
The unit just under the wheel that turns with the wheel,it has a spring used as wiring inside it.They can be spun and then when you put new wheel on and turn full lock can break and cause light to stay on.Not sure if your car uses same system though bud.
Old Aug 23, 2008 | 01:13 PM
TIFF's Avatar
TIFF
Chasing Radders
oh no....that is fitted as normal
Old Aug 23, 2008 | 01:40 PM
Fil's Avatar
Fil
ELASTIC BAND
worth seeing if anyone on www.rs246.com or other audi forums are close to you with a proper lead,
Ive got one, but WARWICK is a long way from me
Old Aug 23, 2008 | 04:24 PM
TIFF's Avatar
TIFF
Chasing Radders
Cheers mate, i will take a look. Been meaning to join up on there for a while.
RockinRein
Aug 19, 2015 07:08 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
RsS2daz
Aug 14, 2015 05:26 AM
Old ford
Jul 31, 2015 06:50 AM
