Oil filter change on a VAG
Old Aug 22, 2008 | 09:40 PM
timb551's Avatar
timb551
Default Oil filter change on a VAG
Need to do an oil change on my toledo this weekend but its a bit different to the ford i have as its a cartridge type filter. Im unsure how to get the filter out though as it seems to have a nut type fitting which is bigger than any socket or spanner ive got. Any ideas?
thanks
Old Aug 22, 2008 | 09:44 PM
markk's Avatar
markk
what year and what engine?
Old Aug 22, 2008 | 09:45 PM
FIESTA CHRIS H's Avatar
FIESTA CHRIS H
not sure of the size but if you get the socket on it should undoe ok. pull the cartridge out and put the new one in the same way. dont forget to fit the new seal if theres one supplied
Old Aug 22, 2008 | 09:55 PM
timb551's Avatar
timb551
2.3 v5
Old Aug 22, 2008 | 09:57 PM
markk's Avatar
markk
36mm socket from underneath iirc. will piss oil all over you !
Old Aug 22, 2008 | 09:58 PM
Danny.'s Avatar
Danny.
Yep undo with big spanner (or grips) and replace cartridge and replace both seals.
Old Aug 22, 2008 | 09:59 PM
timb551's Avatar
timb551
ok ill get it on the ramps tomorrow and have a good look at it, thanks
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
155lee
Oct 27, 2015 04:55 AM
dombanks
Sep 21, 2015 08:38 PM
bassboy
Sep 10, 2015 08:54 PM
Adam Graham
Sep 6, 2015 06:04 AM
