frst breather issue HELP!!!!!!!
Old Aug 22, 2008 | 04:38 PM
picky775's Avatar
picky775
Default frst breather issue HELP!!!!!!!
Ive got the breather with the thin pipe from inlet and thicker pipe from rocker cover but there is another pipe at the bottom of the breather were does it go to?????
Old Aug 22, 2008 | 04:54 PM
picky775's Avatar
picky775
Anyone
Old Aug 22, 2008 | 05:43 PM
picky775's Avatar
picky775
surely someone must know
Old Aug 22, 2008 | 05:45 PM
crazycage's Avatar
crazycage
goes to the air box
Old Aug 22, 2008 | 05:46 PM
picky775's Avatar
picky775
I aint got onethink this could be my running problem
Old Aug 22, 2008 | 05:53 PM
crazycage's Avatar
crazycage
deffo not .whats wrong with it now??
Old Aug 22, 2008 | 05:54 PM
picky775's Avatar
picky775
its runnin a cossy cone filter so no airbox
Old Aug 22, 2008 | 05:58 PM
SiZT's Avatar
SiZT
down into the crank case and your running problem will be because the engine is sucking in air after the throttle body through the hole in the bottom of the breather
Old Aug 22, 2008 | 06:11 PM
picky775's Avatar
picky775
But surely if the pipe is meant to go to the airbox then it will be sucking in air anyway??
Old Aug 22, 2008 | 06:14 PM
SiZT's Avatar
SiZT
nope, they have a one-way type valve, I can't for the life of me remember its name though its a P---- valve
Old Aug 22, 2008 | 06:27 PM
Chris69's Avatar
Chris69
you need to block it off initially as this will help your running problem, short term that'll help but you need to get a 1 way valve on there then it will run better and still be 'breathing' as such.
Old Aug 22, 2008 | 06:53 PM
picky775's Avatar
picky775
Cheers folks got one off crazycage runnin better now cheers fella
Old Aug 22, 2008 | 06:56 PM
rushty's Avatar
rushty
av a look m8 near your injectors there is a vacume pipe there which needs to be conecterd up hope this helpes
Old Aug 22, 2008 | 06:59 PM
picky775's Avatar
picky775
all sorted fella cheers
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
