wasted spark question
Old Aug 21, 2008 | 09:17 PM
BEN FRST's Avatar
BEN FRST
Default wasted spark question
How does this system actually work as i have a problem with mine. Running a P8 i have been told that i donot need a driver fitting as it already has the protocols inside and it has been switched on. I get how the idea works but how do the ignition amps link to the ecu and coil pack. i know that each amp runs each side of the coil but what gives them this signal.
Old Aug 22, 2008 | 04:59 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
the signal is controlled by the p8 ecu pin 24 and 25 are standard, pin 24 and 26 are for the second ignition amp, 24 is common 25 and 26 are the trigger signals
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
