t3 turbo on a small turbo escos
Old Aug 20, 2008 | 05:53 AM
liamford's Avatar
liamford
Default t3 turbo on a small turbo escos
is it possible too put a t3 turbo on an st escos, my escort needs a new turbo there is currently a (smoking) t28 turbo on it, the car had been rebuilt before i bought it with low comp pistons, is this possible or will it mess it up?
cheers liam
Old Aug 20, 2008 | 11:59 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
cheers liam
Just get the T28 reconditioned mate, should not be too expensive, try turbo technics, great prices at the moment
Old Aug 20, 2008 | 01:15 PM
liamford's Avatar
liamford
yeah i prob will end up doin that, but i just wondered if i would see a difference as i would like a little more out of the car if i could?
Old Aug 20, 2008 | 01:16 PM
RWD_cossie_wil
stick with the T28 mate.
Old Aug 20, 2008 | 04:01 PM
redrsmk5's Avatar
redrsmk5
i run a T3 on mine and its not slow
Old Aug 20, 2008 | 10:08 PM
stevev6's Avatar
stevev6
Im running a T34 on mine which was a T25, converted it to webber marrelli mangement to run it.
Old Aug 21, 2008 | 05:44 AM
liamford's Avatar
liamford
what manifold did you use? the maniold from a large turbo? or kept the small turbo manifold, also did you need too change anything else or just the turbo?
cheers buddy!
Old Aug 21, 2008 | 07:41 AM
GUZZLER's Avatar
GUZZLER
T28 from turbo technics are £550 + vat, T3 (4x4 saff) is £426 + vat.
you can use them on the small turbo manifold but why you have the turbo off it may be worth changing the manifold aswell, the small turbo manifold is restrictive, if you look where the turbo bolts on the hole is a lot smaller than on a 4x4 saff of escos manifold.
Old Aug 21, 2008 | 09:14 AM
liamford's Avatar
liamford
i have a large turbo manifold in the house, hmmmm may just do it! cheers guys
Old Aug 21, 2008 | 09:17 AM
liamford's Avatar
liamford
is the a difference in the 2wd too the 4wd turbo's? (t3)??
Old Aug 21, 2008 | 09:38 AM
GUZZLER's Avatar
GUZZLER
angles are different on a 2wd unit, but can be changed, it may need an actuator bracket aswell.
Old Aug 21, 2008 | 10:16 AM
auralisRS's Avatar
auralisRS
I had a new T28 turbo for my mine, as it got problems. Got it from TT, hybrid one, bit more power, don't know what they did to it, bigger rota.
auralisRS's Avatar
auralisRS
Hope it helps
Old Aug 21, 2008 | 07:16 PM
redrsmk5's Avatar
redrsmk5
cheers buddy!
Couldnt tell you mate as truly dont know, car was running it when i bought it and still is, doesnt hang around though!
Old Aug 21, 2008 | 08:17 PM
georgie1's Avatar
georgie1
what better a t28 hybrid or a t3
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
james kiely
Aug 28, 2015 08:58 PM
Cosnada
Aug 27, 2015 09:15 AM
IAN RS2k
Aug 18, 2015 07:51 PM
