Advice Before Start Fitting B&M QUICKSHIFT
Old Aug 19, 2008 | 08:53 PM
anvini's Avatar
anvini
Default Advice Before Start Fitting B&M QUICKSHIFT
Hi mates!!
I will start fitting my new B&M QUICKSHIFT KIT next Week, so
Can any one advice me about correct fitting, technical advice, things to keep in mind before, during & after complete installation??
I had read that this kit will increase noise inside the car, vibration from the engine is transmitted along the linkage in to the floor of the car which makes the car extremely noisey and unpleasant to drive,
Is it true??
Many thanks
Old Aug 19, 2008 | 09:04 PM
picky775's Avatar
picky775
yes mate it is true,project rs of here has done it and is not very happy with the amount of noise and vibration through the car.if you go on zetecinside.com and click on gearbox on the left of the page and scroll down to the bottom of the page you will see the modification to sort it.hope this helps
Old Aug 19, 2008 | 09:18 PM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
Originally Posted by anvini
Hi mates!!
Is it true??
Many thanks
hi mate, i fitted a short shifter from rally designs which cost me Ł30.00. this is a fraction of the cost you have paid I pressume as mine is a dit kit meaning I had to modify my existing gear shifter. My advice to you is dont get anoyed, as yours is the proper b&m (gods bollox kit) should be straight forward, take your time and have the car as high as possible. I did mine using a car jack and bricks with hardly no room what so ever, I nearly took a sledge to it a few times!!lol Put a post up when you have fitted about how good or not so good it is (i couldnt get hold of one)
Old Aug 19, 2008 | 09:20 PM
dave_y's Avatar
dave_y
noise and vibration isnt too bad, only noticeable above say 3k revs when you are caining it anyway and exhaust is more noisy/intrusive at that point.
Old Aug 20, 2008 | 06:05 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
http://www.fastfordmag.co.uk/resourc...AF234_tool.pdf
Old Aug 20, 2008 | 06:31 PM
project rs's Avatar
project rs
finished mine today as picky775 said was noisy but have put 4mm rubber round the 4 mounting studs so the car and quickshift have this 4mm rubber gasket and is fine now
Old Aug 20, 2008 | 08:43 PM
anvini's Avatar
anvini
Hi mates!!
Many thanks for all advices.
Hi Project Rs
Could you tell me where did you get the 4mm rubber gasket for B&M??
Also, could you put pics??
CheeRs
Old Aug 20, 2008 | 08:52 PM
Shep_Cobain's Avatar
Shep_Cobain
how long does it take to fit, and anvini... where did you buy the quickshift from?
Old Aug 20, 2008 | 09:01 PM
vroooom ptssssh
It Wasnt Me!
christian&beccy seems to be the best for price atm. send him a PM.
Old Aug 20, 2008 | 09:43 PM
picky775's Avatar
picky775
here you go fella
Old Aug 21, 2008 | 12:24 AM
anvini's Avatar
anvini
Originally Posted by picky775
here you go fella
Hi picky775
If you fitted the rubber mounts, the B&M gearlever assembly will fit lower down than a standard fitment without them??
Could you put pics of B&M fitted on car??
CheeRS
Old Aug 21, 2008 | 07:36 AM
project rs's Avatar
project rs
thats where i've put my rubber too but it's only 4mm i had it lying round when tightened it squashed to 3mm so will be a bit lower but not noticable, you can't see it on the car so can't get you a pic sorry
Old Aug 21, 2008 | 08:23 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I can't really see the point in rubber mounting it. That will only introduce some potential movement, which is kind of defeating the object of fitting one in the first place!
I removed my lower centre console and bonded it all together from the back. It's made up of several components and you can successfully bond these together with something like Stikaflex. It will still look factory from the front and on mine that tamed the vibration down no end.
Old Aug 21, 2008 | 11:32 AM
muz's Avatar
muz
Wye Valley Hardcore
I`m going to be fitting mine this weekend. Am I right in thinking you dont need to use the standard shifters return springs?
Old Aug 21, 2008 | 01:47 PM
anvini's Avatar
anvini
Hi mate!!
A friend told me the same.....
"""I can't really see the point in rubber mounting it. That will only introduce some potential movement, which is kind of defeating the object of fitting one in the first place!""""
Do you have pics of your installation???
I think they will clarify us many ideas........
CheeRs
Old Aug 21, 2008 | 02:21 PM
Christian and Beccy
#1 in Spelling Club
My B&M is installed as per the instructions. Nothing different, just fitted carefully, with everything clean and greased as it should be. The standard gasket that goes between the shifter assembly and the body is still used. All the guts get stripped out of the standard shifter assembly, return springs too.
If you remove the lower console and look at it from the back, you'll see what needs bonding.
Old Aug 21, 2008 | 02:41 PM
anvini's Avatar
anvini
Ok!!
I´ll keep in mind....
Thanks
Old Aug 21, 2008 | 09:28 PM
dave_y's Avatar
dave_y
make sure you don't have any loose change in the ash tray that will remove most of the noise/vibration
Old Aug 21, 2008 | 09:54 PM
Christian and Beccy
#1 in Spelling Club
Old Aug 22, 2008 | 01:26 PM
anvini's Avatar
anvini
Hi Muz
If you could make pics of installation would be very helpful..........
Good Luck!!
CheeRs
Old Aug 22, 2008 | 04:37 PM
Christian and Beccy
#1 in Spelling Club
That Fast Ford link above has pics.
j.hammond1
30
Oct 31, 2021 05:28 PM
track.focus'd
Aug 12, 2015 05:53 PM
Tinshaw
Aug 4, 2015 09:16 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
fatboy billy
Aug 3, 2015 08:34 AM
