offset et32 any good for escos
as above just after peoples opinions and what size spacers would be needed. Is it adviseable to use spacers or should i look for wheels that are correct offset.The wheels im after arent made anymore i think but ive found a set, Any help appreciated thanks.Rob
Ive just bought some RL7's ET33 wheels for mine.
Ordered spacers and new wheel studs. You can use any size spacer you want really to bring et between 10 - 20? Your choice.
What wheels you seen?
nope.et32 is closer to focus/sierra.
you can use spacers but im not a fan.if you do use them makes sue they are hubcentric spacers.these fit into the back of the rim rather than just sitting inbetween.
