polybushing the back end of an es cos?
Old Aug 17, 2008 | 09:21 PM
AJC's Avatar
AJC
Default polybushing the back end of an es cos?
now, ive been told not to do it!!
is this so...
or s it just the fact it taks a long time? my rear trailling arms need doing and thought i might aswell do the lot whilst im at it,
cheers
Old Aug 17, 2008 | 09:27 PM
El Grand Tomismola's Avatar
El Grand Tomismola
Soild mount your beam Andy - like me.
Also - my old beam was polybushed, but my new one is on standard bushes.
In my own opinion they are as good as each other
Old Aug 17, 2008 | 09:46 PM
AlexD's Avatar
AlexD
Post Miester !
Poly bush the rear beam mounts (big doughnuts) and rear anti roll bar.
Leave the wish bone bushes if they are not worn dont touch them imo.
I have been told if you poly bush the wish bones it trasmits vibrations thru the car.
Old Aug 18, 2008 | 07:11 AM
Bullett's Avatar
Bullett
mike r told me to ploy the rear beam bushes and the anti roll bar but replace the trailing arm bushes with original ford bushes.for the best set up for handling. i had the full poly bush set already though and the original ford bushes are damn expensive too.not that thats major but at the time i already had the full bush kit so it seemed stupid not to use it.
for me im dure it will be fine as im never going to track it so i doubt i'd even notice the difference like mike.
Old Aug 18, 2008 | 07:13 AM
NEEDFORSPEED's Avatar
NEEDFORSPEED
i know someone with a newly powder coated rear beam already poly bushed andy lol car looked ace yesterday btw
Old Aug 18, 2008 | 09:07 AM
bigpower's Avatar
bigpower
Andy,
Ive a new full set if you need!
Old Aug 18, 2008 | 10:03 AM
AJC's Avatar
AJC
cheers all, i heard something along those lines,
mark, you have text.
cheers karl, will see how much mark wants to releive me of first, the beginning of going big bufty
Old Aug 18, 2008 | 10:04 AM
AJC's Avatar
AJC
does it not vibrate like a bar steward
Old Aug 18, 2008 | 02:25 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Do NOT fit these, not only do they vibrate, but they wear out really quickly and will need replacing every few thousand miles even with normal road use.
Old Aug 18, 2008 | 02:27 PM
rog's Avatar
rog
What about Nylon ones?
Old Aug 18, 2008 | 02:34 PM
Stu @ M Developments's Avatar
PassionFords Creator
To add to thsi further andy, they wear out fast because the standard one doesnt have any bushes in it at all, its a spherical bearing. So essentially, what you are asking is:
Should i remove my original zero tolerance high tech spherical bearings, and fit some round pieces of soft rubber in their place?
Hope that helps.
Old Aug 18, 2008 | 05:23 PM
AJC's Avatar
AJC
you mean the rear arm bushes?
thank you mike
Old Aug 18, 2008 | 05:24 PM
AJC's Avatar
AJC
Hope that helps.
cheers stu, it does help thanking you
Old Aug 18, 2008 | 06:08 PM
redrsmk5's Avatar
redrsmk5
Mine are fine Andy and ive had no problems or the slightest vibration, you can drive mine next week at the meet (if dry) if you want and see what you think, i know 2 BIG people on here have said not to but how much do they actually move to wear out???? hardly at all.
Old Aug 18, 2008 | 06:14 PM
Your kidding surely? They move with every undulation of the road! They move teh same amount as your dampers as they are the hinge point for the semi independant supension!
I suspect your talking about teh front donuts?
Old Aug 18, 2008 | 06:17 PM
PewteRS's Avatar
PewteRS
Yours will never wear out coz i expect it will be trailored everywhere from next year
Did look good again yeaterday mate
Old Aug 18, 2008 | 07:26 PM
El Grand Tomismola
With solid engine and box mounts, it adds little more vibration than normal
Old Aug 18, 2008 | 10:30 PM
turbomook's Avatar
turbomook
I've just had my entire front and rear end poly bushed. Maybe noticed a tiny bit of vibration, but seems good to me.
That does not sound good about replacing them every few thousand miles tho, as there a nightmare to fit
Old Aug 19, 2008 | 07:37 AM
Mike Rainbird
Caraholic
Or the fact that it will make your car handle like a piece of shit?
Old Aug 19, 2008 | 05:23 PM
AJC's Avatar
AJC
thank you mike
is that correct mike? just th rear arms or anything else?
cheers
Old Aug 19, 2008 | 05:40 PM
Mike Rainbird
Caraholic
cheers
On the rear, only change the main beam bushes and the ARBs, under no circumstances put poly bushes on the rear trailing arm bushes (2 inner and 2 outer) .
Old Aug 19, 2008 | 05:44 PM
AJC's Avatar
AJC
thank you mr rainbird, much apreciated.
just need to order some new ford trailing arm bushes then
Old Aug 19, 2008 | 06:18 PM
KSA-Cossie's Avatar
KSA-Cossie
Good luck andy,one set has been discontinued m8.
Old Aug 19, 2008 | 08:45 PM
Gez500's Avatar
Gez500
Default Poly bush?
After reading the above posts, I'm slightly confused over what is the best thing to do. I bought a full set of Powerflex bushes a while back and haven't got round to fitting them yet.
Can someone please confirm which is the better thing to do, and is there any chance of some photo's to show what goes where?
Cheers, Gez
Old Aug 19, 2008 | 09:27 PM
redrsmk5's Avatar
redrsmk5
Why under no circumstances Mike, im curious now? i spoke to a few people off here whilst doing my underside resto recently and nobody said not to change them for poly items, and as has been said above one of the sides to the rear arms is discontinued so what choice have you got
Ive just done mine and honestly theyre fine, poly bushed rear ARB but put the standard ford main beam bushes back in as i was told very reliably that they were the best bushes available and that ford spent a lot of time in there development.
Old Aug 19, 2008 | 10:12 PM
Kelv's Avatar
Kelv
Almost there!
Andy, another sugestion then
why not get a fully adjustable rear beam, then just fit decent poly bushes to the anti roll bar and the actually beam mounts!?
Old Aug 19, 2008 | 10:16 PM
Kelv's Avatar
Kelv
Almost there!
what did you put in the trailing arms Mart?
the trailing arms are the ones that are the best bushes available and thats had alot spent within there development, as they are speherical bearings.
i know they are quite alot more expensive than the poly's but id fit those 100% over polys.
Old Aug 20, 2008 | 07:43 AM
Mike Rainbird
Caraholic
Marty,
You have got them round the wrong way, it's the main beam bushes that should be changed and the trailing arm bushes retained . You were either told incorrectly or misinterpretted what they said .
All you have to do is read Stu's statement and if you know anything about engineering, you will swap the standard beam bushes for poly items and the trailing arm ones back to the OE spherical joints . Mind you, I don't think it will matter too much, loading it on and off a trailer .
Old Aug 20, 2008 | 07:45 AM
Mike Rainbird
Caraholic
Cheers, Gez
I'm confused at your confusion, as it has been explained several times in this thread - and the reasoning behind it .
However, for the hard of reading, DO NOT REPLACE THE OE TRAILING ARM BUSHES WITH POLY ITEMS .
Old Aug 20, 2008 | 09:26 AM
ECOS95's Avatar
ECOS95
Thats my plan.
Old Aug 20, 2008 | 02:14 PM
AJC's Avatar
AJC
well im buggered on what to do now i hear they have been discontinued
kelv, i hear you but my bank manager says other wise unless i sell the saff!!!
Old Aug 20, 2008 | 03:54 PM
redrsmk5's Avatar
redrsmk5
Marty,
Trailer!!!!!!!!!!!! Dont you swear at me Mr Rainbird
thats one thing i dont do!! instead i spend nearly 3 hours cleaning it at each show when its got wet
Anyway it would appear ive done mine the wrong way round then as i have poly bushes in the swing arms and the standard ford rubber bushes in the beam, but considering i do 2k miles roughly a year im not that fussed. I couldnt keep the bushes in the trailing arms as they would have melted when they were powder coated, and because one of them wasnt available ( or so i was told by ford) i had no other option but to poly bush them.
Old Aug 20, 2008 | 03:59 PM
redrsmk5's Avatar
redrsmk5
yellow Poly bushes from the Rallye Design book you gave me
Old Aug 20, 2008 | 06:14 PM
AJC's Avatar
AJC
looks like im going to have to go poly
Old Aug 20, 2008 | 07:01 PM
Bullett's Avatar
Bullett
ive had to poly bush mine as i already had them and i needed it doing so it was drivable to get to harvey's. if i couldve done the oe at the time i wouldve.
so what happens if you get an adjustable ream beam?do they run different bushes completely? or are they all poly or standard ford style?
what do we do now we cant get them from ford then?
Old Aug 20, 2008 | 07:21 PM
ECOS95's Avatar
ECOS95
They use Rose Joints inplace of the inner & outer bushes depending on which beam you buy.
Old Aug 21, 2008 | 07:08 AM
rog's Avatar
rog
I have nylon bushes on the back of my car (black solid plastic) Have done since I bought it 7 years ago, never had and problems with it, and I only found out I had them on the car this week....
Old Aug 31, 2008 | 10:12 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
The main prob is the metal sleeve moves around in the poly bushe in the arms by squashing the poly bush.
You can see the effects if you strap the car down tight on a rolling road.
Old Aug 31, 2008 | 10:29 PM
Are they actually knackered?
Old Sep 1, 2008 | 12:10 AM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
i have my old beam and trailing arms for sale mate if you want??? there grubby will need cleaning up and painting but all the bushes are fine the main beam is polybushed too!?
if your interested let me know
