Electrical Oil pressure/temp gauges
More boost Igor!
I need a combined oil pressure and oil temp gauge, and like these two from Burton,
Racetech:
Mocal:
but it looks like they need a capiliary feed. I already have an oil pressure gauge but that's capiliary fed, and never fitted it because I didn't fancy having an accident with hot oil spraying me in the face from the A Pillar.
Is there such a thing as a combined pressure/temp gauge that's electrically operated, and what will I need to fit it?
Racetech:
Mocal:
Yes there is combined lecky ones, you just need a temp sender in the oil somewhere, could replace sump plug with one, easy job then and a pressure capsule on the t piece that feeds the turbo/oil light.
