strut brace
Old Aug 14, 2008 | 06:39 AM
rsnutters1's Avatar
rsnutters1
Default strut brace
in the process of fitting a brace and i'm unsure of the best why to secure to the strut tops. The options are nut and bolt or is the best way to thread so there is no bolt underneath?
cheeRS
Old Aug 14, 2008 | 07:03 AM
wirralphil's Avatar
wirralphil
pva glue lol, no chance of some thin nuts to fit underneath?
Old Aug 14, 2008 | 07:11 AM
R5FORD's Avatar
R5FORD
nut and bolt it mate.. you can get nuts in its hard and annoying but they do go in eventully.
Old Aug 14, 2008 | 07:33 AM
Jimboxr4x4's Avatar
Jimboxr4x4
As said nut and bolt. Its a bit tight trying to get the ones at the back in but it can be done with a bit of patience. This is the easiest way to get the rear bolts on: Tape a bolt to the end of a thin screw driver or use a bit of blue tack or similar. Then have a second person working inside the engine bay, looking down through the drilled hole who can line up the bolt exactly using something like a braddle poked through the drill hole. Once bolt lined up the person underneath just keeps pressing the bolt up flush with the hole whilst the person screws the nut down from above. Takes a few second doing it this way. Good luck.
Old Aug 14, 2008 | 08:18 AM
mad_on_Series_one's Avatar
mad_on_Series_one
toodle pip !
i would use a locking nut as well just to make sure they don't vibrate lose
Old Aug 14, 2008 | 08:39 AM
R5FORD's Avatar
R5FORD
or mask tape the nut in the socket..just around the edge tho and then the rest is the same as above.
Old Aug 14, 2008 | 10:12 AM
vibrating_cake's Avatar
vibrating_cake
sorry to hijac the thread.... but how much difference do strut braces really make.... other than looking cool =)
Old Aug 14, 2008 | 02:53 PM
mad_on_Series_one
toodle pip !
i imagine they reduce flex on the chassic therefor keeping the geomertry were it should be ?
do correct me if i'm wrong
Old Aug 14, 2008 | 06:12 PM
They aid stability big time under heavy braking, that is what I have found, and make car feel tighter and more composed.
steve.rst
Mar 15, 2016 08:01 AM
155lee
Oct 27, 2015 04:55 AM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
155lee
Sep 23, 2015 01:27 PM
