genuine escos spoilers...
A customer had his spoiler sprayed the other day and the Sprayer said the bubbles was due to the aluminium strips the the screw go into reacting with the steel screws.
Do you think he's right?
my theory on it is the skin is too thin and the air bubbles break through esp as it seems to get worst once people rub them down and respray them.
Lucky for me I've never had this problem with my Monte
Dan you at Nat day? gonna need a set of engine mounts for the Fiesta (descided on normal not competition)
A lot of cars were recalled and spoilers replaced because of the problem so they would have been orig paint.
His has bubbled where the strips would be and so has mine
fuck it anyway paints worse elsewhere
so big stickers are on order
Yep will be there rain
or shine
I was told that it was FA to do with the paint, it was the material the BT spoilers were made of. Obviously this was remedied with the ST models (as was everything else that was wrong with BT).
thats similar to i was told years ago by a guy who used to paint the ones that went back to the local Ford dealer, air gets through the spoiler & trapped under the paint, he used to rub all the paint/primer off, seal them up with a special primer then repaint them.
Mark_
40
Oct 2, 2015 04:40 PM
