A Pillar Trim Problem
Old Aug 13, 2008 | 06:52 PM
DANROM's Avatar
DANROM
Default A Pillar Trim Problem
Hi, does anybody knows how to fix the RS TURBO A pillars wich are completly deformed???
I think it is a common fault on all RS S2. This is the third I have and all of them have those horrible deformed trims.
Old Aug 13, 2008 | 07:01 PM
webby80's Avatar
webby80
do u me the lumps on them mate cause they are supposed to be there i think
Old Aug 13, 2008 | 07:03 PM
DANROM's Avatar
DANROM
yes, that is
Old Aug 13, 2008 | 07:05 PM
webby80's Avatar
webby80
yer im dam sure they are like that from new mate , i took one off a 3i i was breaking once and they looked as if they are molded like that from new
Old Aug 13, 2008 | 07:13 PM
DANROM's Avatar
DANROM
Your right, I have never sin any A-pillar trim stright
Old Aug 13, 2008 | 07:17 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i like the wrinkled a piller trim it unique
Old Aug 13, 2008 | 08:57 PM
iansoutham's Avatar
iansoutham
OCD Victim
No, they should not be like that. New, they are the same shape as the A-pillar, although with a "grained" effect.
These were the ones on my old XR3i. Not bad, but have seen better
The ones on the Cabriolet are immaculate though
It is all to do with UV-protection. The shape of the windscreen naturally lends itself to the suns UV shrinking the plastic trims. If you get a good set, keep them coated with a light silicone spray (once a month is fine). This helps keep them subtle and protected from UV attack.
I may have a set of new ones in the collection somewhere. If I can find them, I will see if they are of use to anyone
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
Russ Payne
Sep 25, 2015 08:29 PM
