Oil Pressure or temperature?
Old Aug 13, 2008 | 04:48 PM
pani_k's Avatar
pani_k
PassionFORD Member
Default Oil Pressure or temperature?
Evening peeps,
Wondering if you had to pick one of the two gauges (NOT BOTH!) to put in your cars, which one would you have? What is more beneficial to know out of oil pressure or temperature?
Cheers!
Old Aug 13, 2008 | 04:49 PM
lead_foot's Avatar
lead_foot
is awesome
Pressure IMHO
Old Aug 13, 2008 | 04:50 PM
LHD220Turbo's Avatar
LHD220Turbo
oil pressure just makes you paranoid all the time!
i'd only go with oil pressure over oil temp if it was a proper mechanical one and a decent make. E.g Stack or defi
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Pressure if its a road car. and BOTH if used on track regularly
Old Aug 13, 2008 | 04:51 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Or buy a dual function gauge that shows both
Renton's Avatar
Renton
Pressure is best for knowing your engine is safe.
Temp helps let you know when the oil is up to temp, so the engine is safer to thrash
Old Aug 13, 2008 | 04:53 PM
CossieRich's Avatar
CossieRich
you can use the water temp on the dash to work out when the engine is up to temp. Oil temp gauge will alret when its too high and you risk destruction
Old Aug 13, 2008 | 04:55 PM
lead_foot's Avatar
lead_foot
is awesome
my oil temp take nearly double to amount of time to get up to a safe ragging temp compaired with my water temp.
Old Aug 13, 2008 | 04:57 PM
pani_k's Avatar
pani_k
PassionFORD Member
My water temp (or CHT temp for the focus) is dodgy at the best of times as it's had a new sender and still plays up/doesn't read/partially reads and sometimes it works properly and don't want to swap the cluster so will be getting an aftermarket water temp gauge to plumb in as it's just easier and more accurate but also wanted an oil one and don't really want to be spending too much on getting both oil temp and pressure so was wondering what's better to have. Seen mixed opinions on what's better to know but I'll let this carry on and see if we get a majority verdict
CossieRich's Avatar
CossieRich
of course, but you can still use it as an indication as to the temp of the engine. I wouldn't run my cossie without and oil pressure gauge but i dotn have a temp one yet
Old Aug 13, 2008 | 07:14 PM
pani_k's Avatar
pani_k
PassionFORD Member
BTTT
Old Aug 13, 2008 | 07:17 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
racetech do a 52mm dual gauge....pressure and temp..
try demon theives
Old Aug 13, 2008 | 09:32 PM
cossytel's Avatar
cossytel
by the time you notice your oil pressure has gone south, the damage is probably done
Old Aug 13, 2008 | 09:41 PM
pani_k's Avatar
pani_k
PassionFORD Member
I did think that to myself even if I noticed the pressure dropping rapidly if there was anything at all preventative or any sort of damage limitation. I have heard of oil pressure gauges being praised though for saving engines before.
Old Aug 13, 2008 | 09:49 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
personally for me, temp, just because my oil temp gets dangerously high.
also it tells you when its safe to rag it, and its a LOT later than when your water temp is up to normal temp, thats for sure.
if oil pressure drops much the engines dead anyhow, so i just ignore that, its paranoia, and not loads better than the red light on your dash imho.
gauges to view while driving hard are utterly pointless in a fast car or a car you using on track, as you have no time to look at them.
even checking what boost your cars holding on a car with mega power is next to impossible in a straight line.
hard use on track or drifting even a rev counter is barely of use as you got better things to concentrate on.
something with a peak recall facility would be your most useful thing unless you just want it for looks and to show off on passionford.
Old Aug 13, 2008 | 09:55 PM
AlexF's Avatar
AlexF
Oil temp...
All you need is to know there is low oil pressure and a warning light will od that just fine!
Old Aug 13, 2008 | 10:21 PM
pani_k's Avatar
pani_k
PassionFORD Member
thanks for the input guys.
the fact that my usual CHT gauge never works properly means I have no way of telling what temperature the coolant is at so will defo go for water temp but wanted an oil one as well just to be sure when is safe to give it some beans and also jsut generally keep an eye on things.
looking good just happens to be a bonus
Old Aug 14, 2008 | 07:54 AM
Jimboxr4x4's Avatar
Jimboxr4x4
Oil pressure. The warning light comes on at something like 7psi but a gauge can show any problems immediately. Definately more important in my opinion if you had to choose one.
Old Aug 14, 2008 | 08:10 AM
Rolls's Avatar
Rolls
I've got both - defi's with alarms to hopefully point out any probs with plenty of time to spare....
Old Aug 14, 2008 | 08:33 AM
Kverna's Avatar
Kverna
Virgin-popper
It Depends. Norris saved his engine because of the pressure gauge at rudskogen when the oilfilter came off
Old Aug 14, 2008 | 10:18 AM
vibrating_cake's Avatar
vibrating_cake
to be fair, if the engine feels slightly "wrong" the first thing i always seem to do is give a quick scan over all the dials (theres enough of em!) and oil pressure would show a lot more of what the engine is doing than oil temparature, you'd still have oil temp with oil pissing out onto the floor but you wont have any pressure.
all down to the driver in the end of the day, how often when you're driving well... "spirited" driving are you looking at the clocks?
i only look when there seems to be something wrong or just after the driving to check if i have done any damage whilst driving.
if you have a temp and pressure sender handy get a duel guage, spend the money once in the first place and you could end up saving it later on!
Old Aug 14, 2008 | 10:24 AM
Ginge !'s Avatar
Ginge !
just finding my feet
thats based on where the gauge is located too also, if its in the block and not a sandwich plate he wouldnt have known till it was too late
oil temo far more important,,, oil presure MOST of the time will be too late to do anything about it not all the time but most times it just tells you the engines dead
ps: i also have both gauges,,, and my oil presure is at 2bar,,,, WAY down on the gauge so a little drop would never be noticed anyway
Old Aug 14, 2008 | 10:34 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
If you driving hard you wont have time to notice any gauge
Old Aug 14, 2008 | 10:38 AM
rapidcossie's Avatar
rapidcossie
Some of the oil press gauges have warning light to give you half a chance of catching a press problem.
I have light set at 30 psi, its flashing at idle etx but I know if im flat out and it comes on I can cut the igniton and still have a chance of saving the engine.
Old Aug 14, 2008 | 10:40 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Sound advice there
Old Aug 14, 2008 | 10:46 AM
Ginge !'s Avatar
Ginge !
you inderstand how fast the engine is actually spinning per second yes ?
going at 130ish then seeing a light and turning off the engine will have NO servo assitance when braking aswell as no REAL control of the car,,,, and a good chance the engines already fucked due the the reaction time to get something sorted
theres a small amount of people who have NEEDED a oil pressure gauge compared to them who needed a oil temp gauge
Old Aug 14, 2008 | 01:46 PM
AlexF's Avatar
AlexF
you dont have to use a 7psi switch.... change it to a 25psi one instead.
Old Aug 14, 2008 | 03:22 PM
pani_k's Avatar
pani_k
PassionFORD Member
I didn't know you could change them? Where could you get them from?
Old Aug 14, 2008 | 04:03 PM
AlexF's Avatar
AlexF
try burton, Deamon Tweeks, Merlin
or even google it
http://forums.lr4x4.com/index.php?showtopic=14363
Old Aug 14, 2008 | 04:06 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Oil temp. You should already have a low oil warning light.
Old Aug 14, 2008 | 05:05 PM
JamesH's Avatar
JamesH
By which time its all over!
Oil pressure and Boost pressure
Old Aug 14, 2008 | 05:06 PM
Dicko&Vacant's Avatar
Dicko&Vacant
definitely pressure for me
Old Aug 14, 2008 | 05:10 PM
JTECH James
Passion for Fords!
since when has a cossie had a servo
ok, heres a question for you....
why do you want to see oil temp?
one main reason for me would to be able to make sure the oil isnt getting to hot.... at which point it breaks down, this can vary between oils, and can vary with oil condition.
how hot is to hot?
when the oil breaks down and looses pressure because you have gone over the oils usable temp
catch 22 then
you dont know when your oil is to hot, without a pressure gauge, ...rendering a big part of your temp gauge useless, oil temp means nothing, unless you can see when it looses pressure.
you would then notice a drop in pressure, waiting for the light is wayyy to late.
the answer is, he NEEDS both gauges
Old Aug 14, 2008 | 05:20 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
If you've ever lost oil pressure, you will know a gauge isn't going to help you!!
Old Aug 14, 2008 | 05:25 PM
JTECH James
Passion for Fords!
i have started to see pressure drop on track due to excessive temp....i didnt kill my engine because i spotted it early.....
and now use pro s and a cooler
Old Aug 14, 2008 | 08:50 PM
AlexF's Avatar
AlexF
oil pressure and oil protection are different things....
As oil gets hot it thins... as that happens you loose pressure.
Pressure is a fairly meaningless measurement!!!!!
Old Aug 14, 2008 | 09:00 PM
OldDan's Avatar
OldDan
Surely regardless of where the sensor is place you'd see a loss of pressure when the filter comes off?! The system aint pressurised then!
Old Aug 14, 2008 | 09:08 PM
JTECH James
Passion for Fords!
im more than aware oil thins as it warms and looses pressure, im talking about going over the oils usable temp...around 120degs on fresh mobile 1, and it breaks down very quickly, infact comes out of all the breather ports.
but how would you know the oil has thinned,or broken down by looking at a temp gauge? all oils are different, and the breakdown point varies with oil age...
a temp reading means nothing unless you know the oils exact breakdown temp....
when it thins it looses pressure, so by monitoring pressure you can see when its too thin
if my temp gauge showed 120degs, does that mean the oils broken down and turned to piss? or is my oil good enough to take 130degs? how do you know without monitoring pressure?
Old Aug 15, 2008 | 04:27 AM
rudeboy's Avatar
rudeboy
I agree with JTECHSAFF ... only by using both gauge indications (relationship b/n press and temp) will give you meaningful information. A trend towards high temps and low press would be important shift to see
If you only have space in the cabin for one get a dual reading gauge.
Old Aug 15, 2008 | 04:40 AM
xurrita's Avatar
xurrita
If you have low press can you not the oil temp go up ?
