Bit of a dilema.......My own stupid fault
Old Aug 13, 2008 | 09:54 AM
TIFF's Avatar
TIFF
Chasing Radders
Default Bit of a dilema.......My own stupid fault
Right peeps......What do you think to this.
I have a P Plate Audi A4 and the steering wheel was a little worn on the top, and it was the plain black style one. So i went on E-Bay and got myself the newer looking one with the chrome rings in the middle of it. Also has the airbag in it like the OE one does so thats all good.
NOW
I went to fit the new one yesterday...........This is where the trouble started
Disconnected the battery ect to de-activate the airbag.
Then started removing the standard wheel........ Now while removing it i broke a couple of wires and i thought not to worry i will sort it when the new wheel goes on. THEN this coiled up reel sprung apart
But as the new wheel was going on i thought not to worry!!!!!!!!!!!
HOWEVER......
Once the OE wheel was off i went to fit the new one that was taken off an R Plate Audi A4..............But the spline that holds the wheel on was smaller.......SO ITS A NO GOER!!!!!!!
Tried to refit the OE wheel back on without the rolled up coil......which i did.
Now i have the OE wheel back on.....BUT
The airbag light is on so it must of been one of the wires that snapped...
And i have no horn......that must of been the coil
NOW do i to the very imbarresing thing and take it to the local VW/Audi specalists and explain what i have done and see if they can sort it.......
OR
Live with no Airbag or horn............And i am someone who NEEDS a horn
Old Aug 13, 2008 | 09:58 AM
dunketh's Avatar
dunketh
Chief Iron Oxide Farmer.
You need at least one of the above, the airbag providing last-minute backup for when the other twat doesnt hear your horn.
Having both dead leaves you totally exposed.
danneth's Avatar
danneth
TORQUE!
well fucked up
Old Aug 13, 2008 | 09:59 AM
TIFF's Avatar
TIFF
Chasing Radders
Originally Posted by danneth
well fucked up
Thanks for that
I think you need both for the MOT anyway
Old Aug 13, 2008 | 10:00 AM
alistairolsen's Avatar
alistairolsen
you also need an airbag for the mot. I would try not to be such a ham fisted cunt in future, and source a replacement wheel that actually fits
Old Aug 13, 2008 | 10:06 AM
dunketh's Avatar
dunketh
Take the bulb out of the airbag light. Its not like they'll test its operation at the MOT.
As for the horn, all you need is some kind of audible warning.
Tie wrap one of these bad boys to your a post and leave the window open.
Old Aug 13, 2008 | 10:08 AM
R5FORD's Avatar
R5FORD
TIFF's Avatar
TIFF
Chasing Radders
PMSL
Old Aug 13, 2008 | 10:12 AM
danneth's Avatar
danneth
TORQUE!
Ginge !'s Avatar
Ginge !
just finding my feet
loose the car and claim off insurance
or give it to the ex as part of the divorce settlement !!!
Old Aug 13, 2008 | 10:17 AM
TIFF's Avatar
TIFF
Chasing Radders
Fuck that....its LPG and owes me nothing
I think "Someone else" should be loosing there car.............. what do you think "Mod boy"
dunketh's Avatar
dunketh
How do you loose a car thats both large and the same colour as a banana?
Giving stuff to ex's is always good. If shes anything like mine I'd replace the brake fluid with piss and keep 12 of the wheelnuts.
Nath's Avatar
Nath
Thats a great idea, you should also have some time to rig up the airbag where it shoots out nails or a big piston ...sorts the rest of the settlement out for you.
CraigJ's Avatar
CraigJ
Air bag not part of MOT just take out bulb for now, but horn is part of MOT.
TIFF's Avatar
TIFF
Chasing Radders
Old Aug 13, 2008 | 10:34 AM
dojj's Avatar
dojj
Resident Wrestling Legend
find the horn wires
fix a switch to the wires
press the switch
horn works
remove airbag light
both bodges but it shoudl work unti you can summon up the courage to go and find out how much audi are going to charge you to fix
they might even tell you you need a new steering wheel
Old Aug 13, 2008 | 10:37 AM
TIFF's Avatar
TIFF
Chasing Radders
Well.....Just bidding on another wheel like the OE one i fucked up.....COMPLETE
Comes with everything so all i need to do is connect 2 wires
Old Aug 13, 2008 | 10:40 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
If your gonna fuck it up, you may as well do it properly!!
I remeber doing the same think to a mk6 escort once, the spiral cable was all over the shop like a slinky spring!!
Old Aug 13, 2008 | 10:43 AM
alistairolsen
if there is an airbag fitted then the warming light must come on and go out with the self check malarkey afaik.
of course id never recommend bridging the lamp with the TC, abs or anything else that self checks at the same time
Old Aug 13, 2008 | 10:55 AM
T3ORA's Avatar
T3ORA
that y your getting me to do the one on the skoda
Old Aug 13, 2008 | 11:29 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Good point!
You gonna come round and ruin it for me then?
Old Aug 13, 2008 | 11:48 AM
Physio's Avatar
Physio
Ahhh who needs airbags & a horn anyway, they weren't fitted to the horse & cart you took your test on
Old Aug 13, 2008 | 11:52 AM
LHD220Turbo's Avatar
LHD220Turbo
you cant take the bulb out on these cos they are a printed circuit arnt they?!
Old Aug 13, 2008 | 12:16 PM
dojj's Avatar
dojj
if it's a little led, just take the unit apart and cover it with some tape
but don't snap it out as you will have to get a new dash
Old Aug 13, 2008 | 12:45 PM
D16PJM's Avatar
D16PJM
take it to a garage and say "iv just bought this car, look what some donaught has done."
Old Aug 13, 2008 | 12:58 PM
dojj's Avatar
dojj
with no steering wheel
dojj's Avatar
dojj
better still, take the wheel to the garage and tell them it came off in your hands
Old Aug 13, 2008 | 03:23 PM
jammy86's Avatar
jammy86
I did this exact thing too on my VAG. new part is about 70-80 quid.... its a sore one.
JAmes.
Old Aug 13, 2008 | 04:08 PM
andyt's Avatar
andyt
Old Aug 13, 2008 | 04:26 PM
Stu.H's Avatar
Stu.H
Forget that Tiff, wheres my return call
Old Aug 13, 2008 | 04:45 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
when i read the thread title i thought it was going to be something serious, like you had crashed will giving it beans. not a poxy steering wheel thread
Old Aug 13, 2008 | 08:22 PM
TIFF's Avatar
TIFF
Chasing Radders
Will ring you tomorrow big boy
Old Aug 13, 2008 | 08:23 PM
TIFF's Avatar
TIFF
Chasing Radders
Who rattled your cage Mr!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 13, 2008 | 08:26 PM
indycos's Avatar
indycos
helooooo!!!
funny cunts
Old Aug 13, 2008 | 08:29 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
cant you just re connect the broken wires?
Old Aug 13, 2008 | 08:32 PM
TIFF's Avatar
TIFF
Chasing Radders
If i could find them i would
Old Aug 13, 2008 | 08:57 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
coil is airbag...as they dont risk the usual brass contacts for airbags...
airbag is not part of the mot, and never has been
Old Aug 13, 2008 | 09:01 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
air bag light is deffo NOT part of the mot test
Old Aug 13, 2008 | 09:07 PM
JTECH James
Passion for Fords!
and as far as im aware we have no intention of it ever becoming testable,
unless of course its been deployed and damaged the column or wheel sufficiently
Old Aug 13, 2008 | 09:35 PM
Rab's Avatar
Rab
Fucking superstar........
Does tiff hacking it apart qualify
