FPR on a rover inlet on ZT engine
Old Aug 11, 2008 | 11:09 PM
xrsi's Avatar
xrsi
Default FPR on a rover inlet on ZT engine
Right i have been looking for a way to retain the origional fuel rail for the rover inlet and fit a fuel pressure regulator to it as the rover item does not look adjustable.
i have found an FSE power boost valve, i know they are all hype in most cases but if it means i can have the pressure adjusted to what i require then so be it, to fir the later type plastic fuel rail as i have for the rover inlet so that is a start, but was just wandering had anyone else used on of these as if there are other options then may save me a few £
And no i cant fit the fiesta regulator as it doesnt fit to the bolt holes in the rail and if i drill and tap it it will split the rail.
Old Aug 11, 2008 | 11:13 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
paul done it on his??
Old Aug 11, 2008 | 11:15 PM
rst in breaking's Avatar
rst in breaking
it wont split the rail if done properly mate, mine hasnt split and had no problems with it , now running a fiesta turbo fpr
Old Aug 11, 2008 | 11:16 PM
xrsi's Avatar
xrsi
is he using the plastic rail?
only way i could poss see it going on is by having a spacer plate machined so that it would in effect twist the regularot rod slightly so that you sould bolt the plate to the rail and then a regulator to the plate. But that plate for the complexity of it would work out more than an FSE power boost valve prob
Old Aug 11, 2008 | 11:17 PM
xrsi's Avatar
xrsi
got any pics mate?
Old Aug 11, 2008 | 11:18 PM
rst in breaking
yes im using the plastic fuel rail, piloted and self tapped like standard and fits perfevt, no crackes or anything
rst in breaking
i dont think i have tbh mate, check my resto, if i have they'll be ner the end
Old Aug 11, 2008 | 11:23 PM
xrsi's Avatar
xrsi
thats the std rover fuel pressure reg in that pic mate
Old Aug 11, 2008 | 11:30 PM
rst in breaking
that was before i changed it lol, il try and get one at some point, il try and get in down the halfway house rsoc meet if you go there 2mo and you can see
Old Aug 11, 2008 | 11:41 PM
xrsi's Avatar
xrsi
if you could please try and get a pic that would be a massive help mate as it would save me £80.
bit far for me to come TBH mate as im from north shropshire! :'(
Old Aug 12, 2008 | 06:22 AM
rst in breaking
literally just drill and tap the fiesta fpr on how the rover one comes off, i think the holes are closer together on the fiester on from what i remember but if you get the right size screws you shouldn't have a problem
Old Aug 12, 2008 | 06:33 AM
PhilM's Avatar
PhilM
PassionBMW.com Member
Push it into place on the rail;
And then, drill, tap, stud, fit the regulator and add some nuts
Old Aug 12, 2008 | 06:47 PM
rst in breaking
he has the plastic fpr but its exactly the same process but on the end
RUBY123
Oct 22, 2023 12:04 PM
big_Rad
Sep 15, 2017 09:36 AM
cos elle
Sep 1, 2015 06:48 PM
mrknifey
Aug 30, 2015 11:48 AM
Bailes1992
Aug 16, 2015 07:14 PM
