fuel pump
can anybody give me a idiot proof wireing diagram for rewireing fuel pump as recently bought a 2wd saph with only 8.7volts at pump or an easy to uderstand way of doing it cheers in advance
run a positive cable from your battery to the boot, run it though a 12v relay (switch side) then through the pump then to earth, and run the solinoid of the 12v relay (to turn it on/off) off your old wires that go to the pump as you will be able to keep the ford safety device thing thats in the wheel well and it will come on and off without u messing about with a switch
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
