anyone run 6.8:1 compression?
Aug 11, 2008 | 06:41 PM
500bhp Cosworth in making
is this too low compression for a cossie, seen a set of pistons with this comp ratio just wondered if this cr is ok for 430bhp,t4,Ported head etc
Aug 11, 2008 | 06:43 PM
Lawnsys is down at 6.9:1 on greys and T34@36psi and seems to do well
Aug 11, 2008 | 06:44 PM
6.8 is ok...........as is 7, 7.2, 7.5, 8.0, 8.5 and possibly even 9.
Aug 11, 2008 | 06:46 PM
Im down there somewhere and have the fastest saf after Rod's.
Aug 11, 2008 | 06:47 PM
suppose you have to make it up with loads of boost!
Aug 11, 2008 | 06:50 PM
Quote:
Originally Posted by
Roosie
but you can, safely. lots of ignition too.
properly low, but as long as you dont fuck things up with big cams, it seems to work just fine.
Aug 11, 2008 | 06:52 PM
Mines run 2 bar now and big cams and doesnt seem to be short on power!
Aug 11, 2008 | 07:10 PM
Danny b ran um in his old saph!
0-60 3.92, 12 sec quater (probably due to the rear end though, lol)
EDIT - think he rans BD16's and only 21psi.
Aug 11, 2008 | 07:15 PM
rapidcossie
your cams arnt long duration are they?
Aug 12, 2008 | 06:16 PM
I went down from 7.2:1 and dont notice any change in the way the car drives off boost.
Aug 12, 2008 | 06:17 PM
Stavros
what do you class as long?
Aug 12, 2008 | 06:21 PM
well whats your duration?
Aug 12, 2008 | 06:22 PM
Aug 12, 2008 | 06:23 PM
that is quite wild actually for a turbo car, but spools well, fair play
Aug 12, 2008 | 06:25 PM
Alot of things on my car are specced for top end power but we still manage to get good bottom end too, just dont ask me how?
Aug 12, 2008 | 06:29 PM
Where is your car making peak power now Euan think mine is 7800 ?
Aug 12, 2008 | 06:30 PM
it makes about the same at 7500 as it does at 8000 now.
Aug 12, 2008 | 06:32 PM
Cool mine is still going up at 7800 then levels i think but still more to do on responce,think the head might be flowing too well
Aug 12, 2008 | 06:34 PM
NEIL A
Cool mine is still going up near 8K i think but still more to do on responce,think the head might be flowing too well
leave it with Alan over the winter and see how how much he can squeeze out of it.
Aug 12, 2008 | 09:28 PM
i run 6.9.1,t4 twin bd 14s at 30 psi and its a dog under 4k
Aug 12, 2008 | 09:41 PM
that could change once its been mapped col
Aug 12, 2008 | 09:44 PM
hopefully glancy,hope the new head inlet etc make a diffrence aswell
they were working on it today,so hopefully mapping starting soon
Sep 1, 2008 | 11:55 AM
col cos1
has it been mapped yet.
keep looking at Euans JE pistons for sale
Sep 1, 2008 | 07:05 PM
yip its done 419@wheels on full boost at just over 3.5k im led to believe
Sep 1, 2008 | 07:41 PM
Stavros
At what what lift? A std RST cam is 270 degrees at 0.1mm lift. You have to be careful when comparing figures, without the lift it's meaningless.
Sep 1, 2008 | 07:48 PM
.399mm valve lift on my cams.
TPM961
Jan 15, 2018 10:50 AM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
