Bleed valve probs
Old Aug 11, 2008 | 05:12 PM
escorted series 1's Avatar
escorted series 1
Default Bleed valve probs
Just fitted my three way in car bleed valve 1 to turbo 1 to act and the center one to bleed to atmosphere.All i wanna do is up it to a 1 bar and its going straight over without bleeding anyone got one tell me if im doing wrong how ive fitted it.cheers
Old Aug 11, 2008 | 05:22 PM
stephenbatey's Avatar
stephenbatey
Have you got it wound right in mate??
Old Aug 11, 2008 | 05:39 PM
escorted series 1
yes rite in so its bleeding no air and it going above what it was before
Old Aug 11, 2008 | 05:47 PM
stephenbatey
Double check your hoses aint split other than that i`d say the bleed valve is goosed mate
Old Aug 11, 2008 | 05:53 PM
escorted series 1
is it rite that with it srewed in i should have the boost i was holding before i fitted it and that when screwed out i should be able to up it a little.
Old Aug 11, 2008 | 06:02 PM
stephenbatey
Wouldn`t know as your ment to go to a tuner and get it set up on a RR. Otherwise your fueling wont be right and your engine wont last long IMO mate
Old Aug 11, 2008 | 09:40 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sounds like you've got it plumbed in wrong!
Yes with it closed you should be boosting the same as before you fitted it.
But without the Fuelling increased to match, any more boost and your going to melt!!
Take it back out and get a Tuner to fit and set it up!!!
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Chas
Oct 5, 2015 07:13 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
