Reconditioned Rear Callipers ???
Post Miester !
After removing mine yesterday, one side is fooked !
Where is the best place to buy a reconned set from ??
Ford do them but they are silly money !
Cheapest I could find. Oh & their new not recon. Just bought a set.
http://shop.ebay.co.uk/merchant/powe...Q_fromZQQ_mdoZ
I rebuilt mine, really not that hard to do....only hard bit is getting the internals back in and compressing the spring inside the caliper!!!
Cost me about a tenner for new nipple from big red, new sliders and bolts. New seals from Graham goode about Ł20 and then a strip down and paint took some time more than cost.
the 4wd ones are wider by 10mm than the 2wd ones
difficult to tell without a ruler really but the bit that grabs the pads obviously has to incorporate a 20mm disc rather than a 10mm disc
the carriers are easy to spot as they are about 22mm wide in the slot rather than about 12mm wide
Alex... 4x4s have the ribs on each side of the centre cutout above the piston whereas the 2wd ones don't. Shite description really but this is how I tell the difference...
4x4
2wd
4x4
2wd
Post Miester !
New callipers on route .... Thanks Mate....
The local shop that was gettin mine, had no carriers with them and
they were re-conned jobbies not even re-conned ford ones
Bugger that !
Al....
Bugger that !
Al....
155lee
Sep 6, 2016 11:10 AM
The Enigma
Sep 12, 2015 10:12 PM
