How did you deal with your escorts underside?
when restoring how did you do it? I personally sand blasted the underneath, applied acide etch primer, then zinc based primer and then sprayed sealant. I havent decided what to do next, i assume underseal would absorb the moisture of the rubbery sealant making it crack?
whats your method of protection? (no condom comments please, well if they are really funny i might forgive one or two)
