problems strarting rs turbo
Old Aug 10, 2008 | 04:29 PM
BRIAN3375's Avatar
BRIAN3375
Default problems strarting rs turbo
Hi can anyone help me out ? I have a 1989 RS Turbo which i cant get started. i am getting a spark and car will go if i put fuel in the air intake .There has been a new fuel pump fitted also but i dont know if tne 2 wires have been put on the correct terminals would this matter ?thanks.....
Old Aug 10, 2008 | 04:36 PM
luke89's Avatar
luke89
Team HOTHOT!
when u turn the igniton on can you here the fuel pump prime? have u checked your gettin fuel at the metering head , if so are you gettin it at the injecters? check the fuel pump relay , and voltage on the fuel pump wires
Old Aug 10, 2008 | 04:43 PM
BRIAN3375's Avatar
BRIAN3375
Im Not Gettin A Lot Of Fuel To The Metering Unit Thats Why I Was Wondering If It Mattered Which Way The Wires Went Because I Can Hear The Fuel Pump Priming .thanks....
Matt Baxter
Sep 16, 2015 08:30 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
A.t.p
Aug 15, 2015 11:37 AM
druidgetafix
Aug 15, 2015 10:22 AM
