mfi chatters!!!!
Old Aug 9, 2008 | 06:19 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default mfi chatters!!!!
had new stage 2 turbo and 31 actuator out on and set up, i took dump valve as it is gay,
and my car chatters when you give it some
Old Aug 9, 2008 | 06:20 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
kool funny but kool
Old Aug 9, 2008 | 06:29 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
didnt know it was possible to chatter?
Old Aug 9, 2008 | 06:30 PM
tobyjug_1988's Avatar
tobyjug_1988
i didnt think it could chatter because of something to do with the metering unit?
Old Aug 9, 2008 | 06:32 PM
T28 RST's Avatar
T28 RST
Ok then
It will be a wee hint of chatter sound, nothing like the real sound you get without the metering head.
Old Aug 9, 2008 | 06:33 PM
project rs's Avatar
project rs
mine chatters on standard turbo just not as loud as efi
Old Aug 9, 2008 | 06:34 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
yea its not cossie chatter but a bit there quite loud to
Old Aug 9, 2008 | 06:51 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Mine chattered a bit more than you'd expect for an mfi car,std boost and std turbo, think the turbo had a bit of play in it which may of helped
Old Aug 9, 2008 | 07:48 PM
nigel b's Avatar
nigel b
mine used to be quite loud on mfi
Old Aug 9, 2008 | 07:55 PM
muz's Avatar
muz
Wye Valley Hardcore
Same here mine chatters like a twat lol.
Old Aug 9, 2008 | 09:27 PM
Gregor's Avatar
Gregor
My zvh chatterd a bit on mfi @ 1 bar but nothing like now it's on EFI @ 1.5 bar :P
Old Aug 9, 2008 | 11:02 PM
marzocchi's Avatar
marzocchi
theirs a flap in the metering unit, and i think that causes it
Old Aug 10, 2008 | 10:29 AM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
wastegate chatter is caused by the waste gate,lol,the metering unit just dampens the noise as its normally shut
Old Aug 10, 2008 | 01:18 PM
vroooom ptssssh
It Wasnt Me!
wrong im afraid
it's actually the turbine stalling when the throtle closes as the boost has nowhere to go so stalls the turbine.
Old Aug 10, 2008 | 07:29 PM
grayzo's Avatar
grayzo
grayzo
indeed ur right its compressor surge no such thing as waste gate chatter
Old Aug 11, 2008 | 12:25 AM
JamboRS's Avatar
JamboRS
focus rs 1672
pmsl
Old Aug 11, 2008 | 04:21 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Metering unit might be fucked too
Old Aug 11, 2008 | 06:06 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
better not be metering unit as it is a recon one from jamsport
Old Aug 11, 2008 | 07:35 PM
ricky_2006's Avatar
ricky_2006
nothing wrong with dumpvalve. i like my baileys
Old Aug 11, 2008 | 07:56 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
my old mfi used to chatter then dump thru the dump valve with a stage 3 hybrid on it
Old Aug 11, 2008 | 08:13 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
the dump valve was ok the start off with but got annoying for me i still got it so might put it back on in the future.
Old Aug 12, 2008 | 08:18 PM
Pat's Avatar
Pat
Mines on EFI + ZVH + T34 + -31 actuator + 24psi = Big Smile on face everytime i let off..
Old Aug 13, 2008 | 01:17 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
DV26 chump valve is the gayest thing since Liberace...
FACT
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
That Phils old car you've got mate?
Old Aug 13, 2008 | 05:24 PM
Pat's Avatar
Pat
It is indeed had it for about 4 months now..
Old Aug 13, 2008 | 07:37 PM
ricky_2006's Avatar
ricky_2006
fact? i must be gay then, coz i like mine
Old Aug 13, 2008 | 10:31 PM
Red_bull's Avatar
Red_bull
come on guys post up some vids of MFI chatters! I would remove my dumpvalve if people show me that i can have some good chatter on MFI
Old Aug 13, 2008 | 10:44 PM
Dragsteer's Avatar
Dragsteer
here you are
http://www.youtube.com/watch?v=4Vcpqxeo3X8
Old Aug 20, 2008 | 08:11 AM
kevnoize's Avatar
kevnoize
RsTurbo crewe ina corna.
haha that sounds like anthony hopkins off silence of the lambs.
Old Jan 5, 2009 | 10:30 PM
anvini's Avatar
anvini
Hi mates!!
How can I get a wastegate chatter on my MFI Escort RS turbo S2??
Maybe I need a MFI TO EFI conversion.......................???
I like this sound better than the "psssssssssss" of dump valve.
http://www.youtube.com/watch?v=am4qbhZM_WA
CheeRS
Old Jan 6, 2009 | 07:06 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
if you want loud chatter you will need to dump the metering unit which means changing management
Old Jan 6, 2009 | 09:12 AM
RSTurboSI's Avatar
RSTurboSI
^^ which isnt as easy as just the metering unit
you'll need a fair bit,
Old Jan 6, 2009 | 09:19 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Read the above posts mate!!
It isnt wastegate chatter, its the sound of the turbo stalling as pressure builds back up to the compressor blades, a dump valve eliminates this (well depending on your boost pressure) so if you want chatter the easiest thing to do is remove your dump valve and be runing above standard boost.
Old Jan 6, 2009 | 09:43 AM
RSTurboSI's Avatar
RSTurboSI
if thats to be i already know that
i was qouting the above post to me
Old Jan 6, 2009 | 10:28 AM
Dragsteer's Avatar
Dragsteer
I have chatter on 1 bar (averything else standard) but only if I take out airfilter. So I dont do this.
I hear before few weeks sound of my mate corrado turbo, he was parked in garage, so he rev it at about 2000 rpm and had loud chatter.
Old Jan 6, 2009 | 10:34 AM
Ade's Avatar
Ade
Fast Ford snapper
Mine chattered like fuck on MFi, proper loud...... it was also proper quick too.......
.....but it also did break soon after
Old Jan 6, 2009 | 10:56 AM
Dragsteer's Avatar
Dragsteer
ade: what did you do on engine? I have chatter on 1 bar but not so loud :S
Old Jan 6, 2009 | 11:05 AM
Ade's Avatar
Ade
Fast Ford snapper
Set it up with way too much boost!
Old Jan 6, 2009 | 11:08 AM
grayzo's Avatar
grayzo
grayzo
to be fair mines on mfi 20 p.s.i boost 220 bhp and it chatters loud
Old Jan 6, 2009 | 11:18 AM
Dragsteer's Avatar
Dragsteer
someone here told that have standard boost and chatter on mfi. how?
maybe metering flap get "soft" ? So have little play , and let noise out. I dont have idea...
