Fuel Pressure
Old Aug 9, 2008 | 10:10 AM
Mathias's Avatar
Mathias
Default Fuel Pressure
Hi,
I have to ask this question, not to make a bullshit adjustment on the fuel pressure.
According to my software spec. the fuel pressure shall be 3bar with vacuum pipe on
and 3,5bar with pipe off. The manifold pressure when the throttle is closed is appr. -0,7 to -0,8 and not -0,5bar.
So shall i adjust the pressure with vacuum pipe off or on?
Old Aug 10, 2008 | 07:01 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Hi Mathias
Quoting Stu's fitting instructions:
3,5bar,with the small pipe removed and plugged,and around 3bar with it all connected as normal
So my guess it's best to set it with vacuum pipe off,but better ask Stu directly
Old Aug 10, 2008 | 07:21 AM
They will normally rise to around 3.6-3.8 with the vac off, when set to 3 bar with it on, the vac OFF setting is the one to get right as this will be under load, so is more crucial than off load.
Old Aug 10, 2008 | 09:44 AM
Mathias's Avatar
Mathias
Thank´s for the info!
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
SMILER258
Sep 28, 2015 09:04 AM
