If i have normal escort rs turbo with efi intake manifold +throttle housing what parts i need to make it work? Now i have rs turbo standard throttle cable cutted with locknut in the housing.
It works but it is not that good it should be.
the throttle cable i think is mate but not sure about peddle, just find an efi xr3i thats being broken- plenty about in ads or scrappies- i got lucky on ebay with my pedal
I bought a new xr3i throttle cable from fords about a month ago so i know they still sell them. Unfortunatly i cant find the part number. Just thought i would mention that the throttle cable clip that secures the cable to the inlet manifold is sold seperately. And by the way that cable on ebay is the right one but a rip off!!!! cheaper if you go to mr ford
Everyone seems to get mixed information from ford. I know i bought one as i have it on my car. Ill try and find the fins code so it might help some ppl out.
Now i use rs turbo standard mfi throttle cable, but it is quite short for it.
If i buy escort efi cable, i have to change the accelerator pedal.. where can i grap one? There is nothing on ebay at the moment, how about ford still available and the price?
Yes the carb one will do. I used the standard one that come off a 1.4l and its the same as the xr3i efi one.
Hi!
I bought today pedal from the scrapyard, it is from carburettor cvh engine.
I went my garage and look down in my rs turbo pedal, i think they are same?
Hi!
Confused.
If the one you got from the scrap yard has a ball joint on the end its the wrong one. The one you need has a tag with a slotted hole in the end.
if you have the cable thereis a simple soloution, make up another plate with a solt and hole in it then drill/rivit it to your exsisting pedal, the time its taken you searching for one you could of made one!
-Pedal from laser escort ( dont know year and engine because it was smashed one but i think late 89-90 and carburettor.
-Clip from efi manifold
-Ford escort MK5 Zetec 1.6 throttle cable
Bit of a thread bump but the XR3i Efi cable is still available from Ford (bought one today) 2 years on from this thread contrary to a few posts on here saying it was discontinued, including someone who was told by Ford lol
The part number is 9C799, FINIS code 6617342
Under 20 quid too
