bottom end rebuild???
Old Aug 8, 2008 | 08:30 PM
SWIFTY's Avatar
SWIFTY
Default bottom end rebuild???
has anyone got the torque settings for the whole bottom end big ends small ends oill pump ect and the head bolts.
or is there some where i can get them from as i carnt find them in an work manuals
thanks
(i am changeing my bottom end as i have cracked the block thats why i need all settings)
Old Aug 8, 2008 | 11:38 PM
cossieDavedree's Avatar
cossieDavedree
if u want a workshop manual emailed to ya i can send ya one
what engine is it 205, 200 block?
Old Aug 8, 2008 | 11:44 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
yea i can get em as well wot engine is it?
Old Aug 9, 2008 | 08:56 AM
SWIFTY's Avatar
SWIFTY
205 mate thats a big big help thanks
Old Aug 9, 2008 | 09:54 AM
cossieDavedree
ok have u got email an email address swifty
that i can send it to
Old Aug 9, 2008 | 11:31 AM
clarke5700's Avatar
clarke5700
main bearings-----renew bolts-yes
main bearings-----stage1-44nm
mainbearings-----stage2 88-102nm
big end bearings-----renew bolts/nuts-no
big end bearings-----stage1-28nm
big end bearings-----stage2-55-60nm
oil pump to cylinder block-----19-22nm
sump bolts-----9nm
sump drain bolt-----21-27nm
flywheel-driveplate-----63-69nm
clutch to flywheel-----17-21
crankshaft pulley-damper center bolt-----122-135nm
camshaft sprocket/gear-----59-63nm
camshaft/rocker cover-----10-15nm
inlet manifold to cilinder head-----19-22nm
exaust manifold to cylinder head-----19-23nm
spark plugs-----28-33nm
hope this helps mate good luck
Old Aug 9, 2008 | 04:58 PM
SWIFTY's Avatar
SWIFTY
thanks mate thats a big big help
Old Aug 14, 2008 | 07:36 AM
borderfox's Avatar
borderfox
clean out aii treads with a tap aswell.......
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
SMILER258
Sep 28, 2015 09:04 AM
pie-face
Sep 15, 2015 10:43 AM
Tank Mike
Sep 10, 2015 07:56 AM
