Dot 3 or Dot 4 brake fluid for Cossie 4x4?
Old Aug 8, 2008 | 04:32 AM
captiva's Avatar
captiva
Default Dot 3 or Dot 4 brake fluid for Cossie 4x4?
As above can anyone help please?
Old Aug 8, 2008 | 07:40 AM
boost mad's Avatar
boost mad
4 at least
go for 5.1 if you can and give the system a good clean out whilst your at it
Old Aug 8, 2008 | 12:19 PM
captiva's Avatar
captiva
Thanks. I was really asking what the factory would have put in as I want to top it up at this moment and as my car came from Italy the hand book is hard to understand as "I no speakee Italiony"
Old Aug 8, 2008 | 12:34 PM
Kverna's Avatar
Kverna
Virgin-popper
Dot 4 I would presume. But if you were to change it, go for dot5.1
Old Aug 8, 2008 | 05:08 PM
Most likely back then DOT3, but all the different dot's mix, they have to be able to.
I too would use 5.1, but DON'T use any race stuff unless changing it very regular, as it absorbs moisture much more readily than others.
Old Aug 8, 2008 | 10:14 PM
captiva's Avatar
captiva
May be I am misinformed as I was told that you can mix 4 and 5 but must not be mixed with 3
Old Aug 9, 2008 | 11:10 AM
boost mad's Avatar
boost mad
thats what i thought
original
Apr 28, 2026 05:20 PM
jason_nike
Aug 18, 2019 10:53 AM
mint_s2
Sep 2, 2015 08:58 AM
c20tbo
Aug 17, 2015 10:19 PM
Old ford
Jul 31, 2015 06:50 AM
