CPS pickup on a zvh
Old Aug 7, 2008 | 01:19 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Default CPS pickup on a zvh
Any pics? I'm considering just sticking with the cvh as i've already got the bits for the cps. I'm after CPS Pickus on a ZVH around the crank pulley if poss
Old Aug 8, 2008 | 03:25 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Field motorsport do a trick bracket setup for the CPS...
Bracket bolts to the rocker...
M Ks Fez has it
Old Aug 8, 2008 | 09:00 PM
Daveysaff's Avatar
Daveysaff
Thats for the phase sensor that dude i think. I've had some bits made to do that part (very trick bit of kit, using a zetec cam sensor. cheap too)
Just need to find/have made a bracket to read a 4 toothed pickup on the crank pully itself, been told that a grp A esos cps bracket will fit with a little modding, but i've never seen one to see if thats right or not
Old Aug 8, 2008 | 10:22 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
D'oh yeah you're right, was a lazy search at work
Good luck luck with actual CPS lol
Old Aug 11, 2008 | 01:06 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
CPS on a ZVH is on the block and senses the flywheel. so you need an EFI flywheel.
Old Aug 11, 2008 | 08:40 PM
Daveysaff's Avatar
Daveysaff
I CBA getting the flywheel machined though
I've already got a 4 lug pick-up ring that i've modded from a cvh sierra, I reckon i'll be able to make something. Had a natter with Jano the other day about it and he's given me a few useful pointers
Old Aug 13, 2008 | 10:17 AM
O.K.C's Avatar
O.K.C
Eruption 101.3fm
If you have a look on the dedicated websites regarding the management system you will find pics and info you need.
As said before you will need to use a GrpA Esc Cos CPS Bracket and fabricate it a little more to fit.
The brackets can be found from A1 Rally sport, GGR, ATM, EA, Tim Finch to name a few.
Regards
DixieTheKid
11
Jun 6, 2020 11:20 AM
davidfordrs
Sep 21, 2015 04:23 AM
biggiejody
Sep 19, 2015 10:25 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
Tony W
Sep 9, 2015 12:08 PM
