2008 fiesta gear stick gaiter
Old Aug 7, 2008 | 12:16 PM
ctraig's Avatar
ctraig
Default 2008 fiesta gear stick gaiter
how do i get plastic ring (attached to consule) off as im trying to replace the plastic boot with a leather?????????
does the ring, pull or screw of ?????? or are there clips or screws?????
Old Aug 7, 2008 | 12:25 PM
zvhturbo29rs's Avatar
zvhturbo29rs
Default twist
try twisting it mate as if you were undoing a jar.
Old Aug 7, 2008 | 12:48 PM
alan12112's Avatar
alan12112
Focus St mk2 310 bhp :D
yep he's right it twists and then pops up
Old Aug 7, 2008 | 12:50 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
Get a flat bladed screwdriver or use your finger nails and gently pull upwards on the silver ring.
If you take the console off, which also pulls off with a short sharp tug you can push the silver ring from the underside. Be careful when you remove the console as to not break the 12V wire.
Old Aug 7, 2008 | 08:17 PM
ctraig's Avatar
ctraig
Default 2008 fiesta gearstick gaiter
CHEERS FLAT SCREWDRIVER DID THE TRICK
Mark_
40
Oct 2, 2015 04:40 PM
SMILER258
Sep 28, 2015 09:04 AM
Marv888
Sep 26, 2015 03:44 PM
