escos 2wd conversion
just done conversion on escos to 2wd and ive used 2wd engine but i am having a few problems, 1st i can not get the revs down bellow 1250rpm ive unplugged isv and i can get revs down as far as 900 but when i put plug back on isv it goes up to 1250rpm, 2nd two wires for oil pressure on escos but only one sender switch is there any way round it any one help cheers
I'd try checking the phase sensor gap for the idling problem, mine idled around 1500 when it was out, worth a try? As for the OP switch, afaik thats not part of the engine loom and only goes to the clocks anyway, so i'd just try and connect one of them and if it doesnt work, swap them round
mk3ste
Oct 17, 2021 10:09 AM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
