Help - Big end shell bearings
Hi.
I'm posting this question on behalf of a friend.
There is a possibility for him to buy a 1993 cossie but there is an "IF", apparently the all car and engine are ok apart from the big end shell bearings.
The question is:
Is this an usual failure?
Could this had caused any other major problems?
All this questions are coz cossies are getting rarer in Portugal and the few remaining ones are being sold for huge amounts of money for their conditions.
This one appears to be ok, apart from the small problem, and this is the opportunity for my mate to make his dream come true
Thanks for your help and understanding.
From Lisbon, Portugal
Gonçalo
The question is:
)Thanks for your help and understanding.
Gonçalo
take it as the car needs a full engine rebuild, if the shells have gone it will probably need a crank grind, then while its apart you may as well rebore & fit new pistons, oil pump etc.... then skim the head, check valve guides etc.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
