cossie rear diff!!??
Old Aug 5, 2008 | 10:50 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
Default cossie rear diff!!??
are the 4x4 rear diffs different from the 2wds??? i know the casings are ie 7inch-4x4 7.5inch-2wd and the driveshaft hubs but are the ratios? and if they are which 1 would be good for acceloration?
Old Aug 6, 2008 | 08:00 AM
rog's Avatar
rog
Have a look here, it can help you a bit
https://passionford.com/forum/general-car-related-discussion/247724-cosworth-4x4.html
Old Aug 12, 2008 | 06:22 PM
cossytel's Avatar
cossytel
yes they are different, but only slightly 3.64:1 vs 3.62:1 this equates to about the same as new tyres vs worn tyres in speed difference, I would not recommend changing. the rwd uses the bigger 7.5" diff because it is stronger and all the power is transmitted through the rear this is why the shafts are also bigger, the 4x4 shares the power through both diffs and therefore doesnt need the bigger diff and shafts. if your car is 4x4 and you fit the 7.5" diff then the front and rear props will turn at different speeds which will overwork the centre diff. to summarise leave as is and replace like for like!
3drRich
Sep 13, 2015 07:32 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
xr4x4rs
Aug 6, 2015 09:03 PM
