greenstuff or redstuff pads
im after new pads for my 283 cossie discs, but want to know would redstuff pads be to over rated for an rs turbo running about 200bhp. are green stuff any good as when i have a few high speed runs i get cooked brakes in no time.
i use redstuff ont he capper, quite hefty on the wallet as brake pads go, but never had a problem with them, although they seem to eat into the brake disks a lot more than other pads.
been on a couple of trackdays with it, standard brakes (aka bottle tops) non vented disks.
boiled the paint on the rear drums but never had fade from the redstuff pads. =)
Put some standard pads in it if its just for road use. Your brakes will feel worse the higher up you go in terms of fast-road/race pads if you don't get them hot, which you probably wont on the road.
I have to say i have used Greenstuff, it was only on standard discs on my van but they worked so well. I tested them quite hard and it cut my stopping distance by 15 yds or more!!! They lasted me for months and months
I tend to stick with Pagid, Ferodo or Mintex. I've 1144's on the RS atm which are by Mintex, they've been spot on. My spare pads are Ferodo DS2500's which I've used along with DS3000's on the EVO - again both very good pads 3000's may be a little overboard on the RS though they DO bite hard and will ware disks faster.
Passionate about fords
on my 4 pots i had red stuff to start with and they were wank, many times i thought i wasnt going to stop. im now using ferrodo ds2500 and the differance is amazing, much more bite from cold and perform great when hot.
dave
dave
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
