brake pressure switch
Old Aug 5, 2008 | 09:10 PM
raggey's Avatar
raggey
Question brake pressure switch
Chaps.
Could any one tell me which is the pressure switch on the brake system, there is a valve on bellow the fluid reservoir and one on the pump any ideas.
Paul.
Old Aug 6, 2008 | 12:57 PM
cozmeister's Avatar
cozmeister
More boost Igor!
It's in the cap on top of the brake fluid reservoir.
On Sierras with ABS, there are two connectors. The three pin one is the normal brake fluid level/handbrake switch and the two pin one is the level switch used by the ABS system - both use the same float for detecting fluid level. The pressure switch is built into the ABS unit.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
cossie330
Sep 27, 2015 04:13 PM
