S1 RST and RS1600i ARB
Old Aug 5, 2008 | 08:02 PM
Dr Frankenstein's Avatar
Dr Frankenstein
Default S1 RST and RS1600i ARB
Are the compression struts and the anti roll bar interchangeable between the RS1600i and the Series 1? Cheers peeps!
Old Aug 5, 2008 | 09:11 PM
JesseT's Avatar
JesseT
Of all the parts, one compression strut only is.
Old Aug 5, 2008 | 09:51 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Here's a couple of pics of a Series 1 ARB, so you can check.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESE:IT&ih=006
Not sure on the answer though!! LOL.
Old Aug 6, 2008 | 07:06 AM
Marc LJX's Avatar
Marc LJX
I didnt think they were compatible.
1600i has ball joint type ends that screw into the tension strut, S1 turbo has rod ends instead.
IIRC MEF make the two different types, i.e not a one size fits all item, so i reckon they are different...
Old Aug 6, 2008 | 10:50 AM
JesseT's Avatar
JesseT
Yes, the ball joint is different, but the strut itself is same on one side. RS1600i has both threaded as RH thread, but the S1 has a LH and RH struts threaded separately.
Old Aug 6, 2008 | 11:06 AM
Marc LJX's Avatar
Marc LJX
Right Im sure the 1600i threads are both left hand? (Because im still scarred from recently fitting two to my car) Which would still make one of the struts the same
Old Aug 6, 2008 | 07:49 PM
JesseT's Avatar
JesseT
Could have been that way too.
A.t.p
Oct 23, 2015 07:54 PM
Fezman1
Oct 2, 2015 01:22 PM
Benleys
Escort Range
Sep 28, 2015 01:56 PM
Billy_RS
Sep 13, 2015 04:17 PM
