steering problem
Old Aug 5, 2008 | 03:57 PM
coachworz's Avatar
coachworz
Default steering problem
my 2wd sapp tends to wonder off when ever i hit a rough or bumpy road.. is there anything i can do to improve this?
have change to poly bush for TCA, ARB , new steering rack, new wheel bearing, 8x18 rims with 235x45x18 tyres. Gaz gold coilovers.....
Old Aug 6, 2008 | 01:39 PM
gray29's Avatar
gray29
hi mate,
dont know whether this is going to help you or not, but i got an st170 had good tyres on it but they were worn (on front) so i put new tyres on it only cheap ones (was a bit skint at time) and got the tracking done at the same time. now no matter what pressure i put in them it wanders when it hits a bump it feels like the off side wheel has a mind of its own!
because i put the tyres on a few months ago have noticed that the off side tyre is wearing on the outside really badly so i reckon the fella has tracked the car badly.
so now what i plan to do is get a full wheel alignment some more new front tyres (named) and then get it tracked again i reckon that'll sort the problem, will let you know.
have you had a wheel alignment? is the tracking out? do you have a weak shock? how much is the car lowered by?
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
DHMC
Ford Fiesta
Sep 20, 2015 06:47 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
