4x4 cossi loom connection.
Old Aug 5, 2008 | 03:48 PM
mustang 390's Avatar
mustang 390
Default 4x4 cossi loom connection.
Fitted a cossi 4x4 engine and loom to a anglia, need to no what the connections are on the 6 pin plug behind the battery on the cossi, ( colours are :- red/blue. black/red. brown/green. brown/white. green. black. ) any help would be great.
Old Aug 7, 2008 | 07:33 AM
Having just done this for my new ecu(emerald), I found they are not as ford state, and some are very different, there are at least three variations.
Here goes, but check yourself with metre/wire etc
I assume although you say behind the battery it is in a different place to 2wd where it is under the dash but right at top behind ecu, same/ish colours.
RED/BLUE = PERMANENT LIVE
BLACK = SWITCHED LIVE(ignition switch)
BLACK/RED = FUEL PUMP(live)
BROWN/WHITE TEMP GAUGE
2wd have thin green which is tacho and a brown/red which is air con leading to a purple relay taped to loom.
BROWN/GREEN should be oil pressure on yours(warning light).
Hope this helps, some cars the oil pressure light sis through ecu loom others through car loom(as mine).
JK12
33
Apr 26, 2021 12:09 PM
truffleshuffle
Sep 10, 2015 09:35 PM
bigryrs
Sep 7, 2015 06:45 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
