anyone got a t34 on a 1600 cvh????
Old Aug 3, 2008 | 06:05 PM
s1cab's Avatar
s1cab
Default anyone got a t34 on a 1600 cvh????
just wondered how laggy compared to t3??
Old Aug 3, 2008 | 06:37 PM
mk3stevie's Avatar
mk3stevie
yeah Ive got one on mine. Is a little more laggy than the T3 n my old series 2 but when she comes on song hits hard
Old Aug 3, 2008 | 06:39 PM
s1cab's Avatar
s1cab
thanks for reply thinking of buying one !!! but wanted opinions first !
Old Aug 3, 2008 | 08:28 PM
crystalbluecossiestu's Avatar
Default dont do it
i had a t34 on my escort cab 1800zvh with a (tubular manifold) the turbo wasn't on full bore till 4500rpm i had it on there for two weeks and got sick of constantly havin to change down gear if i wanted to get any where i now run a t3 and its so much more fun and exactly the same power as the t34
Old Aug 3, 2008 | 09:21 PM
s1cab's Avatar
s1cab
what sort of power are you running?
just that i'm aiming for 320bhp now and a t3 on 1600 is pushing it.
Old Aug 3, 2008 | 10:13 PM
didn't realise you was running that kind of power my misses drives mine so it's staying at 198.8bhp other wise it will end up in a ditch.
With that kind of power i think its hobsons choice as you will go through t3's like there no tomorrow, as it happens i still have the t34 and if your interested reply back. If your running a t34 you will need to make up a spacer plate 12mm to go between the manifold and the turbo to clear the manifold, or www.autospeacalsits.co.uk do a tubular manifold and the turbo bolts straight to it with no spacer plate it also helps with the lag. The other problem is space, fitting it in without having to fit a new radiator ever 3 miles because your acuator has gone through your radiator yet again!!! i went through 3 rads but mine is a mark 5 cab so there is less space in mine for the rad and cooler.
Old Aug 3, 2008 | 10:31 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
T34's on 2L engines are at full boost by 2500rpm, so there must have been something wrong with that 1.8 because there's no way it should have come in at 4500!
Old Aug 4, 2008 | 08:40 AM
is that a zeetec turbo or a zvh because the cab has been on the rollers and the operator didn't say there was anything wrong?
Old Aug 4, 2008 | 12:52 PM
DazC's Avatar
DazC
The T34 on Stevies car is on a 1620cc engine. That was on full boost by 4k. Deffo something miss matched on that 1800!
chowfornow
14
Jan 5, 2019 09:01 PM
Russ Payne
Sep 25, 2015 08:29 PM
