Making up seat adapters
Old Aug 3, 2008 | 04:44 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Making up seat adapters
If you were to make up a plate to join a seat frame to runners, where the runners are wider and longer than the seat frame, what thickness metal would you be using ?
I am thinking along the lines of a plate to attach onto runners, with holes in the right place for the seat frame to bolt onto, maybe double thickness where the holes are for stiffness, etc...
Thanks
Greg
Old Aug 4, 2008 | 09:03 AM
frog's Avatar
frog
BTT with additional question, what metal material should I use ? Mild steel, aluminium plate
Old Aug 5, 2008 | 05:44 PM
fonfe's Avatar
fonfe
i used stainless steel 10 gauge (just bigger than 3mm thick) to adapt rs2000 recaros into the other halfs fiesta ZS n its been fine.
Old Aug 5, 2008 | 08:49 PM
frog's Avatar
frog
Thanks
S3an
Sep 26, 2015 11:39 PM
Kam B
Sep 24, 2015 10:40 AM
S3an
13
Sep 13, 2015 10:01 AM
cambo205
Ford Fiesta
Sep 6, 2015 07:45 PM
hopper350
Sep 4, 2015 12:53 AM
