help using cam belt tension gauge
Old Aug 3, 2008 | 11:51 AM
florent78's Avatar
florent78
Default help using cam belt tension gauge
I buy this product
but to be honnest, I've go some difficulties to understand how it works.
Don't know if somebody already use it here, but I need some hep
this is the manual
what is the cambelt thickness, cambelt load and cambelt deflection ???
thanks a lot
Old Aug 7, 2008 | 06:38 PM
3dormatt's Avatar
3dormatt
Ignore it. just tighten the belt untill you can twist it by hand through 90 degrees on the longest side and your good to go!
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
