Help!!!!!!!!!!!!
Old Aug 2, 2008 | 02:47 PM
Tev's Avatar
Tev
Default Help!!!!!!!!!!!!
right just been to fill up the car for later and as ever with a cossie it's started playing up,
i pulled on to the duel c way n gave the car some beans in 3rd changed in to forth n went to do the same in 4th but the car felt really sluggish, was having a real job boostin up!
i backed off limped home, ive just popped the bonnet to c if i have any sort of leaks but i cant find a thing, any 1 got any ideas?
Old Aug 2, 2008 | 02:49 PM
dazzle740's Avatar
dazzle740
might be your actuator but hard to tell to be honest
Old Aug 2, 2008 | 02:57 PM
Tev's Avatar
Tev
i was thinkin along that line but that its new
Old Aug 2, 2008 | 03:16 PM
mechanic28's Avatar
mechanic28
seems like its overboosting did you fit the actuator etc?
Old Aug 2, 2008 | 03:24 PM
Tev's Avatar
Tev
over boosting fella??
yer i fitted it, bout 4 months ago, has been working fine?
Old Aug 2, 2008 | 04:09 PM
mechanic28's Avatar
mechanic28
ah ok lol!git be the actuator fitment !just wondered as you said it had a new one etc!!does it run fine,boost up in the other gears?
Old Aug 2, 2008 | 04:20 PM
Tev's Avatar
Tev
yer sorry fella that was my fault not explainin properly lol
it felt strong in second and third but i didnt really hold it open, just felt pup in 4th so i backed off??
Old Aug 2, 2008 | 04:21 PM
Staffi's Avatar
Staffi
What about tomorrow dude??
Sounds very odd just for it to be in 4th gear.........
Old Aug 2, 2008 | 04:26 PM
Tev's Avatar
Tev
i dont think its just 4th, everything's pointing to a weak actuator spring although i will b pissed if it is
i will still come tomorrow fella dont worry,
i really need to get the car to stu
Old Aug 2, 2008 | 04:28 PM
Staffi's Avatar
Staffi
Thought the actuator was new dude??
Just an easy drive down fella...
Does sound actuator related Tev........
Old Aug 2, 2008 | 04:34 PM
Tev's Avatar
Tev
new ish bout 4 months old
Old Aug 2, 2008 | 06:17 PM
LHD220Turbo's Avatar
LHD220Turbo
if you just filled up, it might be shitty fuel? that would give you the symptons your describing
did you use a different fuel?
i always use v power (99 ron) in mine; but i couldnt get any this one day, as i was low i had to use BP ultimate (97 ron) and the car felt as if it had problems boosting, so much so i thought i had developed a problem
Old Aug 2, 2008 | 07:11 PM
Tev's Avatar
Tev
yer i had just filled up, from the same shell station i use, v-power as usual,
