coil overs
I've read a few times that if you are fitting coilovers that you have to have the rear struts reinforced so the big question is how many people have had this done or is it a myth
fookin hell kelv,thats bomb proof!!!!!!! no chance of the struts popping through with that set up
most folk dont bother to be honest but the rear arches around the struts normally has to be "dressed"
with a big hammer to give clearance for the springs as there is very little room
you could always use one of the Danny B rear strut braces and aid it by having the rear turrets welded.
(the rear triangle sections where my cage comes down to join the rear turrets)
jonfoc
Sep 11, 2015 04:46 PM
