ecu help
Old Aug 1, 2008 | 10:50 PM
nobbie_b's Avatar
nobbie_b
Default ecu help
alright guys i not had my cossie for long and i was wondering wat it the main difference between the ecu's i e the level 6 and level 8 ones, is it worth getting the level 8 one for my car. are they plug and play etc
cheers guys
Old Aug 1, 2008 | 10:54 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
With a level 8 you can run launch control and anti lag, theres some datalogging software that MSD sells that you can use too. Its pretty much plug and play, you'll need a chip of course and a PF09 throttle sensor and you'll need swap the wires round inside the plug for the TPS. L8 runs quicker too iirc.
www.bigturbo.co.uk some useful info on there mate
Old Aug 2, 2008 | 06:42 AM
L8 is a higher spec, and SOME can run closed loop, as said outer wires on tps need swapping or do at ecu end instead.
Old Aug 2, 2008 | 07:26 AM
nobbie_b's Avatar
nobbie_b
Default cheers
cheers guys so until im running more power its prob not worth it but get one ready for wen i am running more power
Old Aug 2, 2008 | 07:30 AM
Stu @ M Developments's Avatar
PassionFords Creator
Just to clarify. They can ALL run closed loop.
Old Aug 2, 2008 | 07:40 AM
nobbie_b's Avatar
nobbie_b
Default advantage
wats the advantage or running closed loop im new to this sorry for all the questions you have prob ansered about 100 times
Old Aug 2, 2008 | 07:48 AM
Have a browse here:
http://www.motorsport-developments.co.uk/rstuning.html
Old Aug 2, 2008 | 07:57 AM
nobbie_b's Avatar
nobbie_b
cheers mate will have a read
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
