help needed please on turbo
Old Jul 31, 2008 | 04:05 PM
georgie1's Avatar
georgie1
Default help needed please on turbo
as above i got a small turbo escort cosworth and i notice that i was get smoke from vent when warm up plus header tank was going down so just thought it was a water pipe from header to turbo maybe leaking just check and it seem ok so watch the engine rev it a few times then where the pipe from header tank con u got this metal thing that cont to turbo is that where it leaking and can i fix or is it a big job
Old Jul 31, 2008 | 04:25 PM
xr4x4rs's Avatar
xr4x4rs
anychance of a pic of what you mean as im struggling to understand what you mean
Old Jul 31, 2008 | 04:27 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i wish i could understand that but i cant probably because you havent used any punctuation surely it would be easier to find where the smoke is coming from on start up first before you go replacing anything thats what i would do anyway hope that helps
Old Jul 31, 2008 | 05:02 PM
georgie1's Avatar
georgie1
it not smoke it steam as it the water from the header tank that go to turbo im hoping it a seal that go to turbo
Old Jul 31, 2008 | 05:45 PM
georgie1's Avatar
georgie1
will try and get pic but if u know the pipe that come from header tank to turbo where the oil feed i think
Old Jul 31, 2008 | 06:57 PM
georgie1's Avatar
georgie1
ere a pic
Old Jul 31, 2008 | 10:16 PM
georgie1's Avatar
georgie1
is there some sort of seal on the chorm pipe as that where i think it leaking as the header tank cont to this
Old Aug 1, 2008 | 10:13 AM
georgie1's Avatar
georgie1
bttt as i do need advice please
Old Aug 1, 2008 | 10:15 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It's obviously leaking as it's corroded? Replace/repair?!
Old Aug 1, 2008 | 10:18 AM
georgie1's Avatar
georgie1
what do i replace and what is it called
Old Aug 1, 2008 | 11:05 AM
Twellsie's Avatar
Twellsie
a bango fastening water feed pipe
Old Aug 1, 2008 | 11:20 AM
GUZZLER's Avatar
GUZZLER
should get away with the 4 sealing washers from Ford.
Old Aug 1, 2008 | 11:21 AM
georgie1's Avatar
georgie1
do i need the whole thing or just need the seals can i get it from fords
Old Aug 1, 2008 | 11:25 AM
georgie1's Avatar
georgie1
what r they copper washers and is it just under bolt and a seal eachside
Old Aug 1, 2008 | 11:26 AM
coswurv's Avatar
coswurv
there just copper washers mate, sometimes its an easy job if the banjo fitting undo, best get the turbo hot then try to loosen them off, obviously take the rad cap off to stop the wather gushing out all over your hand
Old Aug 1, 2008 | 12:05 PM
georgie1's Avatar
georgie1
cheers guys
Old Aug 4, 2008 | 09:14 PM
georgie1's Avatar
georgie1
hi guys i change the washers where banjo fitting both of them but it stil piss out but not from them in the pic u see the turbo ,you see the brown thing,the wastegate i think but dont know what it call behind the bonjo fitting u see the nuts it leaking on the bottom one i tried to tight up but didnt more so is this a big job now
Old Aug 4, 2008 | 11:50 PM
georgie1's Avatar
georgie1
help need can i fix it or what do i need
Old Aug 5, 2008 | 07:56 AM
picky775's Avatar
picky775
maybe if you typed properly people would understand what your talking about,the way your typing is like your not english,use proper english and you may get a better response.hope you get it sorted.
Old Aug 5, 2008 | 09:49 AM
georgie1's Avatar
georgie1
bttt
Old Aug 5, 2008 | 09:51 AM
Jim Galbally's Avatar
Jim Galbally
dont BTTT the thread, re-type it in english
we do not understand what you mean
georgie1's Avatar
georgie1
and im not very good at spelling but then im not a scouser
Old Aug 5, 2008 | 09:55 AM
J1mbo's Avatar
J1mbo
B1mbo
tbh rather than wasting hours trying to sort it take it to a garage and they will prob sort it in a hour and cost ya Ł40 !!
Old Aug 5, 2008 | 10:14 AM
georgie1's Avatar
georgie1
thanks jimmy ur info was good
Old Aug 5, 2008 | 10:16 AM
georgie1's Avatar
georgie1
i was trying to see if i can do it as i dont thing it going to be 40 pound anyway thanks for ur hepl m8
Old Aug 5, 2008 | 10:20 AM
georgie1's Avatar
georgie1
if you look at pic you can see turbo , i have change the washers on the banjo fittings as i thought it was leaking from them,but it seem it not like i said if you look at pic you can see the brown thing behind the banjo fittings ,there is six bolts i think one at the bottom is leaking can i tighten it up as i tried and it didnt move
Old Aug 5, 2008 | 10:55 AM
picky775's Avatar
picky775
if youve tried tightening it up and it didnt move then obviously its already tight.youre best bet is to take it to someone that knows what there doing as said above.By the way im not a scouser i live in wallasey witch is over the water from liverpool.
Old Aug 5, 2008 | 12:32 PM
georgie1's Avatar
georgie1
anymore advice would be good ,do i need to take to garage or can i do it myself as i rather try and fix it any ideas please
Old Aug 5, 2008 | 12:33 PM
R5FORD's Avatar
R5FORD
just but a banjo with a take off that accepts braided line and run that to the header tank.
Old Aug 5, 2008 | 01:06 PM
xr4x4rs's Avatar
xr4x4rs
hopefully this will help you out
where the banjo bolts are you can see its leaking, you need to replace these with copper washers and tighten them up, but may need to clean the ends so they seal properly onto the turbo core
now if iim rite in what yuou have said, ive marked the bolts you refer too
if these are the bolts then all that does is old the exhaust housing of the turbo onto the core, there is no water in the back part, if there is you will know about it as your exhaust will be chucking white smoke out and that would should the water seals have gone inside the turbo, but there not as theres no signs around those bolts to show a water leak
the only part that has water round it is the centre piece where those banjo pipes are bolted on
Old Aug 5, 2008 | 01:51 PM
georgie1's Avatar
georgie1
thank you alot m8 i have done the copper washers ,but it seem like it coming out of the bottom exhaust housing bolts any ideas
Old Aug 5, 2008 | 02:29 PM
xr4x4rs's Avatar
xr4x4rs
are you sure its wayer coming out and not oil
water would leave a white makr down there and oil would just look wet
Old Aug 5, 2008 | 04:54 PM
georgie1's Avatar
georgie1
it water as it steam up cos of the heat plus my header tank is always going down
Old Aug 5, 2008 | 05:01 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
maybe one of your banjo braized joints has split....?
Old Aug 5, 2008 | 06:46 PM
georgie1's Avatar
georgie1
just checked the banjo pipes and they are ok ,maybe the coppers washers wasnt thick enough so may need another one
Old Aug 5, 2008 | 08:00 PM
LHD220Turbo's Avatar
LHD220Turbo
i had this problem; have you got 2 copper washers on the water banjo to turbo? 1 each side?
they have to be really tight
Old Aug 5, 2008 | 10:47 PM
georgie1's Avatar
georgie1
yeah i got one each side i might put another eachside and see if that helps thanks for the replys that helped
Old Aug 6, 2008 | 07:58 PM
georgie1's Avatar
georgie1
doh i tighten a bit to much as it snap ,lucky it came out by hand
Old Aug 6, 2008 | 08:24 PM
LHD220Turbo
you snapped the banjo bolt mate?
Old Aug 6, 2008 | 08:26 PM
georgie1's Avatar
georgie1
yes and i didnt go that tight i may do what rsford said and aero quid
